Maximum Spark Advance?
Old May 10, 2007 | 07:29 PM
vetteboy86's Avatar
What determines maximum spark advance? I know on my Firebirds I set the maximum spark advance to come in at 3000 RPMs at about 36 degrees. What can a fuel injected car run. Reason I ask is because I have recorded 43 degrees. The maximum spark advance set in programming was 43.95.
Thanks,
Craig
Old May 10, 2007 | 08:56 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Maximum Spark Advance?
Maximum spark advance that you can run may not be the optimum for your motor. Maybe the question should be "what is the least spark advance that I can run."
If a motor makes the same power from 28 degrees advanced to say 31 degrees advanced I would take the 28 degree number everytime.
Old May 11, 2007 | 07:28 PM
vetteboy86's Avatar
So is there any harm in setting the timing in the rpm vs. advace table to go no higher then 36?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
Jorlain
Oct 8, 2015 01:57 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Jlanz55
Sep 9, 2015 09:09 AM
