my new cold air intake
Old May 16, 2007 | 09:49 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
well i finally took off my old bad flowing air intake and built and installed this cold air intake. it was only 40 bucks. i very happy here are some pics
Attached Thumbnails my new cold air intake-car-018.jpg   my new cold air intake-car-019.jpg
Old May 16, 2007 | 10:30 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Re: my new cold air intake
Very nice CAI, only thing I would worry about is that rust on the strut tower tops
Old May 16, 2007 | 10:45 PM
79malbiu's Avatar
Is that the one from ebay?
Old May 17, 2007 | 10:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Sure looks like it.
Old May 17, 2007 | 01:37 PM
90CamaroTBI's Avatar
Car: 91 Formula, 89 IROC
Engine: LB9, LB9
Transmission: 700R4, 700R4
Axle/Gears: Posi 2.73, Posi 2.73
Looks like the one I bought on Ebay.
Old May 17, 2007 | 09:56 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
I was going to say the same thing! A CAI would be the least of my worries.
Old May 17, 2007 | 11:10 PM
Car: 91 formula
yes this is the one from ebay. the guy was telling me there is no way this will fit my 87. only 88-89. but i knew he was wrong. only took about 30 min to install and i was good to go.
Old May 17, 2007 | 11:22 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
I was gonna buy one of these off eBay, but EVERYone on fbody.com told me they were *****.
Old May 18, 2007 | 07:46 AM
Engine: LB9, LB9
I love mine. Could just use a K&N filter.
Old May 18, 2007 | 08:15 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
how does that work better than what gm did?
It looks like when you close the hood the filter is still in the hot engine bay. My fathers mustang has a similar setup that actually goes in the fender to get only cooler air not heated by underhood air. If you had modified your tpi(cut the bottom out) air box and used kn filters when the hood was closed only cool air would have gotten to your intake. just curious on your thoughts?
Old May 19, 2007 | 07:32 AM
jkicak's Avatar
Car: 87 Formula 350
the stock 1987 is known to be the WORST setup for an fbody intake system and just about anything is an improvement. if the guy has opened the back of his cowl on his formula like me then there is a built in heat extractor and this will keep the temps under the hood WAAAY down and create an airflow under the hood to keep the area near the headlights (where his airfilter is) cooler than you would think.
here is my setup:
Old May 19, 2007 | 11:20 AM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
i see. I have been through the same stuff myself and just bought a cowl hood and made it fuctional. The isolation of underhood air completely is the way to go. As your underhood temps are still hotter than you think but definetly an improvement.
Old May 20, 2007 | 01:30 AM
Car: 91 formula
im still thinking on how to make more cool air to come into the engine without changing my formula hood. Im thinking of cuting the bottom were the filter is located and try to make a path for cold air to come in. oh here is a pic of my old stock intake THE WORST INTAKE EVER PUT ON A FIREBIRD
Old May 20, 2007 | 06:35 AM
jkicak's Avatar
Car: 87 Formula 350
you make it sound like you have to cut the hood or something.. all you have to do is remove the 4 bolts in the pic below and the plate comes right off.. it is as simple as could be! then if you don't like it for some reason you can just bolt it back on.
Old May 31, 2007 | 08:02 PM
87-4MULA's Avatar
Car: 1987 Firebird Formula
yeah i was just checking that out today and the guy emailed me and told me that it wudn't work. I was convinced otherwise. the only thing i dont like about it is where it connects right up to the TB but hey its only $50 as compared to SLP's $250 set up. I have room to play around with it.
Old May 31, 2007 | 09:13 PM
WhiteKnight's Avatar
Car: 88 GTA
Transmission: Manual
Inregards to the formula hood mod. We did that to my friends formula and it made a decent difference. Did you take both pieces out or just the solid piece? We left the mesh style one in for asthetics. Stupid GM. I still can't figure out why they did that.
In regards to CAI. I made mine out of 3" ducting from home depot and sealed it with a bit of silicone. Its pretty air tight. Not exactly the most beautiful CAI in the world but asides from the cost of the K&N filter the CAI cost me 2 bucks. We made the tube longer before the bend and instead of a 45 degree angle the bend is more like 10-15 degrees. We then cut a whole in the side of the engine bay so that the filter could be stuffed half way into the fender to get some cold air from outside the engine bay as well.
Old May 31, 2007 | 11:39 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I have a 90 formula and I plan to modify the stock air box. Gonna just cut a bigger hole in the side and weld on a matching pipe that runs to the fender opening. I can't really bring myself to buying an SLP kit, not much difference from what came stock
Old Jun 1, 2007 | 12:44 AM
Car: 88 GTA
<----- Where did you get your display pic from? Looks like its a wallpaper or something and if it is looks like a damn sweet one.... soory to get off topic
Old Jun 1, 2007 | 04:35 PM
87-4MULA's Avatar
hey i got a question for you on that kit. what size pipes did they give you? Im just curious. i might do the same thing
Old Jun 1, 2007 | 05:48 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
IIRC when I asked the seller he said 3".
That's why I backed out. I need 4".
Old Jun 2, 2007 | 09:22 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
Axle/Gears: Junk 2.73s
i was wondering if you removed all of the pollution nonsense, like the air box and pump...i cant tell from the pictures
Old Jun 3, 2007 | 09:30 AM
Car: 91 formula
the air box yes. when you say pump if you mean air pump then no i still have it. and i still have the emissions hoses and lines hooked up to my headers.
Old Jun 10, 2007 | 06:00 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
im thinking about getting one of these but i was wondering if the one you got is the Bomz Racing one or the EautoRacing...they look the same...
Old Jun 10, 2007 | 06:33 PM
Car: 91 formula
it is the eautoracing one.
Old Jun 10, 2007 | 06:50 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
cool...thanks
Old Jun 27, 2007 | 01:24 PM
shocker89bird's Avatar
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
As far as the heat. A simple mod for the time being is to cut two pieces of cardboard and put one near the side next to the radiator to block some of the heat from under the hhod, the second cut a piece to fit over the top of that piece and the top of your piping.
Also for the more adventurous I cut out the factory battery tray area so it could be a true cold air. i removeda piece of plastic underneath so it gets coldair from the air dam but doesn't pic up water since the filter sits on the bumper brace.
Hope that helps.
Old Jun 27, 2007 | 03:36 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Too bad it doesn't go any further. My intentions are to cut a whole in that area and run my filter below.
Old Jun 27, 2007 | 04:17 PM
Car: 89 ws6
Transmission: t-5
Axle/Gears: 3.08
That is how I made mine. I had a local shop here in Illinois where i got the 3.5 inch aluminum piping and made it myself. Bought the 3.5 to 3 in couplers online to fit to the mass airflow though. Picked up huge gains over the the stock firebird pieces with the cone filter at the end.
Old Jun 28, 2007 | 05:23 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Where in Illinois did you find it?
Old Jun 28, 2007 | 10:05 AM
Car: 89 ws6
Transmission: t-5
Axle/Gears: 3.08
I found it at Behind Bars Race Cars in Lak in the Hills. They do custom turbo kits and roll cages. They have a web page and I can give you the number if you need it. I basically just bought two large 90 degree elbows which were huge so I had plenty of piping for it to go straight as well.
Old Jun 30, 2007 | 08:58 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
LITH? I'll look 'em up. Thanks.
Old Jun 30, 2007 | 03:45 PM
Car: 89 ws6
Transmission: t-5
Axle/Gears: 3.08
I will try to get a picture of mine but it is out of the car seeing as how I am doing a 411 computer swap right now.
Old Jul 20, 2007 | 07:08 PM
Celticsfan's Avatar
Car: 1985 Trans Am
Transmission: 700-R4
hey will this fit an 85? ive been looking and the only one ive seen is slp for $300...no thanks haha
Old Jul 20, 2007 | 08:03 PM
92fireformula's Avatar
Car: 92 Firebird Formula
Engine: 5.0 tpi
Go to ebay and search 1985 trans am air intake and you will find that one for 40 bucks
Old Jul 21, 2007 | 08:36 PM
Celticsfan's Avatar
Car: 1985 Trans Am
link? i typed it in and nothing
Old Jul 21, 2007 | 08:40 PM
jakesTA87's Avatar
Car: 87 Trans Am
Engine: 350(5.7L)
Transmission: WC T5
http://cgi.ebay.com/88-89-Pontiac-Tr...QQcmdZViewItem
http://cgi.ebay.com/88-89-TRANS-AM-G...QQcmdZViewItem
Old Jul 21, 2007 | 08:45 PM
Celticsfan's Avatar
Car: 1985 Trans Am
ya ive seen these but they will fit my 85 ?
will this work? since there all cheap why spent 60+ when i can get it for $40
http://cgi.ebay.com/ebaymotors/1988-...QQcmdZViewItem
Old Jul 22, 2007 | 08:57 PM
Celticsfan's Avatar
Car: 1985 Trans Am
anyone?
Old Jul 23, 2007 | 02:38 AM
F-Body Demon's Avatar
Anyone tell me if this actually makes a difference. For $40 I would do it.
Old Jul 23, 2007 | 07:13 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
That should fit your 85.
Cold unrestricted air going into your engine is always a good thing. I noticed a tenth at the track between hot air and a cold restricted air intake.
Old Aug 5, 2007 | 11:29 PM
ideasjr's Avatar
Car: 1991 Camaro RS
Engine: 305-(Soon to be a 350)
Transmission: R4
can i get a cold air intake for my 91 rs?
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
