Is your throttle body closing?
Old Sep 11, 2000 | 04:30 PM
S10Wildside's Avatar
I had a similar problem, my throttle body didn't close all the way. You may have to put on another spring from the throttle cable bracket to the throttle body. It's worth looking into. Strange thing about mine was that it was fine when the throttle body was cold, but when it heated up it would stick a little.
1982 S-10 Wildside
355 TPI, Accel High-Flow Intake, Ported Plenum, Arizona Speed & Marine Runners, TPIS AFPR, Edelbrock BBK 52MM Throttle Body, 1993 Typhoon Drivetrain
Old Sep 11, 2000 | 06:09 PM
Lounge Lizard 6's Avatar
I've got a POS re-bore 52mm from TPIS and it sticks at all positions but mostly near idle. Added an additional spring and it solved most of the problem.
Mike
'90 IROC-Z, 5-speed, ZZ4, Trick Flows
Moderator SEThirdgen
Old Sep 11, 2000 | 06:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, I had to do the same thing with my TPIS 52mm TB. Since I dont have the TV cable with my manual trans, I put a spring on that spot on the TB, and to the throttle linkage on the side of the plenum. It works great.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
