Old Sep 11, 2000 | 09:52 AM
phebus1's Avatar
I have what is a 350 ZZ4 short block with Vortech heads The heads I am having drilled to accept the TPI set up. The car currently has a 305 HO TPI in it. any insight into problems with this. I will also be adding a stall converter, Edelbrock TES headers, roller rockers. I will be swaping the injectors, will the ones out of a new Vette work?
85 T/A 5.0 H.O.WS6 TPI Auto,3:43 SFC's,STB,K&N Air filter,AFP,8.8 wires. Was my 70 year old Moms car 48000 org miles
Old Sep 11, 2000 | 10:23 AM
Bill91Z
Guest
Posts: n/a
Shouldn't run into any problems. Your biggest restriction will be your lower intake, may want to port it or buy aftermarket, other than that, should be simple. 19lb 305 injectors will work fine, but you can use any from Lt1s or buy new SVO injectors which are decently priced. Don't think LS1 injectors are different, but don't quote me on that .
-Bill
1991 Z28, 305TPI, 5-speed,
AS&M ported & polished intake, AS&M polished LTRs, AS&M port matched plenum, TPIS 52mm TB, Richmond 3.73s, SSM SFCs, SLP LCAs, SLP panhard, ATR 3" exhaust, MSD 6al, Taylor 10mm wires, SLP PROM, and a host of other stuff.
Old Sep 12, 2000 | 02:15 PM
phebus1's Avatar
I tried to lay the manifold from a TPI on the long block and there is no way the ports will line up Looks like I'll have to wait for the new manifold to come out in Oct.
Old Sep 12, 2000 | 02:23 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I heard the LS1 injectors wont fit, but you can use any out of an 85-97 TPI or LT1 car.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
