help with a 350 tpi build up
Car: 1991 CAMARO RS
Engine: 305TPI SOON TO BE 350 TPI
Transmission: 5 SPEED
Axle/Gears: STOCK FOR NOW
im looking to build a 350 tpi motor my my 91rs i have been pricing parts and all that and i have came up with a list.. my problem is im only looking for the 350hp to 475hp range. I would like to get good gas milage and daily driver reliability.
any heres the list if you guys could look it over make changes if needed or list out the problems i have with the parts i have picked that would be great.
https://www.jegs.com/webapp/wcs/stor...OrderCalculate
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: help with a 350 tpi build up
Are you thinking of a stroker motor and/or NA (any power adders?) I could not figure out your link for parts, so
Wheather its a stroker or not, an NA engine that I would build today for a third gen car would be: (seeing that I am spending your money)
heads: AFR 195 Elimenators or larger Trick Flows
Cam: 224/230 or a bit bigger
intake: HSR
1 3/4" headers with full exhaust.
some kind of ram-air effect.
And learn to tune it yourself by programming Eproms.
Shoot to build peak Hp at around 6200 to 6400 RPM.
Make sure it runs cool by installing an excellent radiator, Griffinth or other.
You will need a beefy tranny: for auto Pro-Built 700R4, manual T56.
And a beefy rear end.
intake: HSR
