Another pesky Idle Problem.....
Old Sep 19, 2000 | 12:18 PM
petemed's Avatar
I have a new (reman) 305 in my IROC. New everything except TPS and IAC. The rpm's seem to 'stick' when shifting gears. For instance, going from first to second if the R's are around 2K, when I push in the clutch the rpm's stay the same. But if I lighty (very lightly) touch the gas pedal the r's will drop back to normal (750). The TPS seems to be working fine....checked the voltage across the full range with my scanner. I have noticed a 'ticking' sound around the back of the intake - could the idle problem be due to a vacuum leak??
1988 IROC-Z
305 5spd
Edelbrock TES
"Keep the wind at your back and the bugs out of your teeth"
Old Sep 19, 2000 | 12:29 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Im not good with 5 speeds but the ticking is probebly your injectors.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
