Vacuum line diagram
Vacuum line diagram
About 3 months ago I tore my L98 down for a rebuild and I'm finally getting it together again. As I took it apart, many of the hard plastic vacuum lines were very brittle and broke apart plus it's been too long to have a clear memory of where everything goes. I was wondering if anyone has a source for a decent schematic diagram of the vacuum line layout? It would be REALLY helpful! (for an '88 L98 if that make much of a diff)
Thanks,
-Tim-
[This message has been edited by irocCJ (edited September 18, 2000).]
Thanks,
-Tim-
I need it too...
I've asked before, with no response - this should be easy for someone to answer.
I need the '89+ diagram though...
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
Check out the T-Ram at my website:
http://www.mylecdekmat.com/mike.htm
I take it that the Vac sticker on your fan shroud isn't detailed enough? I have an 88 IROC that I just got back together and I went by the sticker diagram. I ended up getting a Shop Man from Helms which has better detail for the the lines.
1988 IROC-Z
305 5spd
Edelbrock TES
"Keep the wind at your back and the bugs out of your teeth"
1988 IROC-Z
305 5spd
Edelbrock TES
Chilton & Helms huh? I guess I should go to the library and see what they have. I have a Pontiac TA factory service manual (from an '86) that has most of the info so I've never looked at the more generic manuals. Oops.
Petemed: those poor radiator stickers have long faded into oblivion ...
Thanks guys.
Thanks guys.
vacuum diagram
I'm doing an engine swap with my 87' L98 and I didn't get the strickers. As far as diagrams, I'll try the local library. Anyone else know where I can get the diagram???
DONT get the Hayes manual. There is no diagram in there.
Vacuum diagrams
I found a site with a vacuum diagram for an L98. Chevythunder There is a lot of useful info in there, (ie electrical, mechanical)
Alex
Alex
MikkoV
Sep 9, 2015 04:25 PM
