Egr solenoid and Coil mounting questions????
Old Sep 24, 2002 | 11:49 AM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
I was just wondering on a 92 tpi car where does the egr solenoid Mount to?? and were does the coil mount? I did a tpi swap and completely forgot. Im tryin to return the car to look as stock as possible.
Old Sep 25, 2002 | 01:21 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
On my '89 the coil mounts on the intake, to the left side (facing) the distributor...kinda in the way to access the distributor hold down bolt, to give you an idea.
Not a 100% sure, but the EGR solenoid would be under the plenum. Been too long since I had mine apart to be sure. What the heck, least I'll bump the post up for ya
Old Sep 25, 2002 | 01:23 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
COULD ANYBODY GIVE ME A PIC OF THIS?>? IT WOULD REALLY HELP>
Old Sep 25, 2002 | 04:59 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
This ones not real clear, but the best I have for the coil.
http://members.aol.com/_ht_a/onebadw...es/tpipass.jpg
The coil is almost behind the transmission dipstick in the pic, just beside the distributor cover plate on the top of the plenum.
Theres a mounting bracket that the coil bolts to, the mounting bracket is held in place by the rear 2 intake bolts on the pass side. They are the bolts that have threads on each end from the hex head, so that another hex nut can be screwed onto the intake bolts.
Old Sep 26, 2002 | 12:08 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
I used custom allen key intake bolts when I installed my TPI is there any alternate mounting location for the coiL>??? and weere does the egr solenoid mount?
Old Sep 26, 2002 | 12:19 PM
2QUIK6's Avatar
I have seen mounting plates bolted to the back side of the heads also. There is usually a couple of bolt holes on the back side of the head. If you have the original mounting bracket for the coil, you can put it in a vice and straighten it out some and bolt it to the back of the head.
As far as the EGR, you could bolt it onto the same bracket as the coil with a little work on it. Or you can bolt the EGR solenoid to one of the water neck bolts, using a similar type double ended bolt.
Old Sep 26, 2002 | 01:26 PM
Brian'sIROC's Avatar
The factory EGR solenoid location is under the coil. It's attached with the same screws as the coil is. The bracket that holds everything mounts to the last two intake bolts on the pass side
Old Sep 26, 2002 | 01:38 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Does not compute.
In your first post you said you want everything to look as stock as possible. Yet you have different intake bolts. When i look under a car's hood to figure out how stock it is, i guarantee i wouldn't care how the coil and EGR solenoid were mounted if i could tell straight up that it had non-factory bolts all over it.
Just confused by your logic. IMHO, the stock coil and EGR brackets are complete POS, in the way whenever you want to adjust the timing. Thus i mounted my coil to the firewall, and trimmed the EGR solenoid bracket off and left it floating at the back of the engine. Now i have all the room in the world to swing a dizzy wrench back there. Unless you're making a concourse restoration, i just don't see any point to retaining that junk.
Old Sep 26, 2002 | 02:16 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
yea i guess my logic is gone on that one. but I couldnt find all the intake bolts so I just went down to krangen and bought what they had. I think I will bolt mine to the back of the head as previously stated. Thanks for all your help!!!!
jklein337
Sep 19, 2018 06:23 PM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
