91 vacuum line help
Old Jun 4, 2007 | 05:21 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
91 vacuum line help
i took apart my motor awhile back and can`t remeber how the vacuum lines go back. any pic`s or advice would be great
Old Jun 4, 2007 | 08:12 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: 91 vacuum line help
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Jun 7, 2007 | 05:23 PM
jaysfs's Avatar
Transmission: t56
thanks,but that didn`t help me much,anyone
Old Jun 7, 2007 | 05:56 PM
tourville's Avatar
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
if you could take pics of the different hoses and what they are currently connected to it would be easier to help you!
Old Jun 7, 2007 | 07:08 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
If figure 24 didn't help you out you're going to need to show us some pics of what you need.
Old Jun 8, 2007 | 08:47 AM
jaysfs's Avatar
Transmission: t56
i`ll try to get some tonite,it`s the lines by the rear plenteum by the distibutor
Old Jun 8, 2007 | 09:00 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Does this help? I know there are more but this is the only pic I have on hand for that area.
Old Jun 8, 2007 | 09:07 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Where do those hoses from the 3 way valve go to?
Old Jun 8, 2007 | 09:15 AM
jaysfs's Avatar
Transmission: t56
that helps alittle,i have to see when i`m off work
Old Jun 8, 2007 | 09:20 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
One goes to a port on the plenum
One goes to the vacuum line for the cruise control
One goes to a hard vacuum line coming out of the firewall for the HVAC.
You can see which is which in the pic.
Old Jun 8, 2007 | 12:00 PM
BA92GTA's Avatar
I have been to this link sooooo many times during my rebuild.....hope it helps....
http://www.chevythunder.com/fuel%20i...um%20lines.htm
good luck....
Old Jun 10, 2007 | 02:05 PM
jaysfs's Avatar
Transmission: t56
i think i have it all together thanks everyone,now the plug for the egr i can`t find ion the wire harness. any help wit that
Old Jun 11, 2007 | 07:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
The EGR solenoid plug? Probably just fell back behind the engine. Don't worry it can't go far. The wire's only about 6 inches long and the tranny is right below it.
Old Jun 11, 2007 | 07:26 AM
jaysfs's Avatar
Transmission: t56
i will check it out tonite,i am supposed to get my new flowmaster 2morrow,then the fine tuning should begin. thanks for the help!
gta892000
Aug 11, 2019 11:16 AM
camarohelp
Sep 12, 2015 05:45 PM
Doobie52
Sep 11, 2015 06:19 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
