cam install??
Old Jun 6, 2007 | 10:24 PM
335_GTA's Avatar
Car: 1991 GTA trans am
Engine: 305 tpi
cam install??
Ok I have a 305 tpi auto it runs 13.7's on good tires and 13.9 on bald.
But my question is I want to change the cam in it. I have just the cam in the garage, What else needs to be replaced when doin a cam swap?
I plan on replacing timeing chain just because it kinda jumps when reading timing.
springs
retainers
stems
What must be changed. For now. I plan on tearing it down this winter and rebuilding it but for now what should be replaced just to make sure it still runs good and gets me through this season.
Any ideas or imput would be great.
Also how big is to big of a cam to where I have to tune my computer b/c of the lack of vaccum or somthing of that sort?
Old Jun 7, 2007 | 12:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: cam install??
A 91 left the factory with a roller cam, so you could just replace the cam itself and reuse everything else. You'd get much better results though if you replaced the springs at the same time to match the cam. Replacing the timing chain is a good idea, but it won't affect your jumping timing at all.
Old Jun 7, 2007 | 12:49 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: cam install??
The Crane 2032 cam that I have is as big (duration) as you can go with a stock 305 TPI and stock chip. A little more lift would be fine if you mod the heads to handle it.
Cam: Crane Powermax 2032 452/465 214(270)/220(276) 112 deg., 1800 to 5800 RPM (2000 to 5500 RPM), P/N 104224 $289.95 @ summit.
Lift (1.52 rockers): 0.458"/0.471"
Lift (1.6 rockers): 0.482"/0.496"
Duration @ 50: 214/220
LSA: 112 degrees
Old Jun 8, 2007 | 04:32 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
Re: cam install??
the whole top end needs gaskets except for the heads. also water pump and timing cover gaskets. 2 oil changes. coolant. garage. a nice fan. and about 2 days off from work. oh and a couple of cases of beer.
Old Jun 8, 2007 | 05:01 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: cam install??
mnorton.... do you have a video clip of your powermax 2032 cam... cause i would like to hear how it sounds at idle..... can u describe it... does it have a stock idle to it.... do you loose any bottom end power.......
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
