big problem, car starts after few tries then shoots up to 1500 rpm then dies. help
Old Jun 7, 2007 | 07:53 AM
87_gta's Avatar
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
hey guys, my problem now is that when i start my car it takes a few shots then when it does start its rough then shoots right up to 1500 to 2000 rpm for like 5 sec then dies. i did just do an injector swap to the car, i have new gaskets, all vacume lines are connected, i try using the miltimeter to check mv but it goes out of range almost immidaitly. Initally no codes came up but then i got code 32, 33 and the next time got code 34. i really dont know whats going on with this car. I took the entire intake off cleaned it up and put the new gaskets on , all the bots went in easy. my fuel pressure is good, all the sensors are hooked up properly, all the vacume lines are hooked up but its still throwing these codes. What could my problem be these are new symptoms that what the car was doing in previous posts i need help please
Old Jun 8, 2007 | 09:11 AM
Vader's Avatar
Re: big problem, car starts after few tries then shoots up to 1500 rpm then dies. hel
Generating a '32' shortly after startup indicates an EGR problem, liokely with the solenoid or diagnostic temperature switch. There is a remote possibility that the EGR vacuum lines are connected incorrectly, and/or that the EGR is opening on startup.
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
kah992
Aug 19, 2015 02:55 PM
hokis
Aug 9, 2015 03:57 PM
Sherpajames
Aug 7, 2015 06:56 PM
