Plenum Porting and runner porting
Old Oct 8, 2000 | 10:08 PM
theformula's Avatar
Ok, I started to port my plenum and I took down the floors that stick up. Now, do i have to port the runners ???? Is it supposed to be done also? How hard is this? Any where that gives a detailed explanation? How do you gasket matched runners to the plenum and intake?
Should I port the sides of the plenum also? It looks like it supports it from collapsing.
What is base porting?
thanks
[This message has been edited by theformula (edited October 08, 2000).]
Old Oct 9, 2000 | 05:42 AM
Chuck Everly's Avatar
Theformula,
I think this question might get more answers in the “TPI Forum” so I am moving it there for you.
Old Oct 9, 2000 | 07:49 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I would do the runners while you have them off. Knock down the wall in the runners where the tubes are attached to the mounting flanges. It may not seem like a lot but take the amount of material you remove and times it by eight and it adds up.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 9, 2000 | 09:46 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
See my efi page. There's some pictures you can follow there.
http://www.isthq.com/~dan/efi.html
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Old Oct 9, 2000 | 03:52 PM
rondubbs's Avatar
http://www.tribal-treasures.com/cars...-port/port.htm
Old Oct 9, 2000 | 07:10 PM
Rob P's Avatar
Engine: ZZ4TPI
Ron,
Nice site there. That polishing job on the upper plenum is nice! Makes me want to pop mine back off and re-do it, or perhaps find an extra one to do. WOW!
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
Old Oct 9, 2000 | 07:36 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Take this link: http://members.tripod.com/~Proformula/porting.html
Looking for:
87 IROC-Z L98
84 TRANS AM H.O.
[This message has been edited by IROC-ZTWENTYGR8 (edited October 09, 2000).]
Old Oct 9, 2000 | 09:34 PM
theformula's Avatar
well its all done. I only took down the restrictive floor. Not the sides. What kind of performance difference can I expect from just doing that.
thanks for the responses guys.
Old Oct 13, 2000 | 12:51 PM
Blade's Avatar
10 horses at the most...
Linson
Oct 24, 2025 02:00 PM
Reid Fleming
Oct 10, 2015 09:56 PM
Royal_Z
Sep 30, 2015 08:45 PM
