vacuum thingy
Old Jun 11, 2007 | 06:12 PM
85ta4bm's Avatar
Car: 85 trans am
Engine: 350 4bm TPI
vacuum thingy
I have an 85 t/a, it's been bout 2yrs since i've started putting her back together after changing the heads, and i'm confused as 2 where this vacuum thing bolts up 2 (i think it goes somewhere on the back of the engine) and where the lines go? I know one of the lines off the T goes to the throttle body (the tape came off of the other lines) heres the pics
Old Jun 11, 2007 | 06:43 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Re: vacuum thingy
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
That is the good old vacume diagram link, but i wanted to say how good the blue matches with the rust.
Old Jun 11, 2007 | 09:53 PM
85ta4bm's Avatar
Car: 85 trans am
Engine: 350 4bm TPI
Re: vacuum thingy
Okay now i got that it's the egr vacuum soleinoid, but what do i bolt it up 2?
Old Jun 12, 2007 | 09:03 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: vacuum thingy
That gets bolted in between your ignition coil and the mounting bracket that's attached to the intake manifold.
Old Jun 12, 2007 | 02:58 PM
85ta4bm's Avatar
Car: 85 trans am
Engine: 350 4bm TPI
Re: vacuum thingy
that's great! I didn't put that bracket back on. Would it hurt if i took the two bolts out of the intake to put the bracket on, or would i have to take the whole intake off, because of the bolt torque sequence? Thanks at least i know where it goes now...
Old Jun 13, 2007 | 07:10 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: vacuum thingy
I believe those two bolts get torqued next to each other in sequence anyway. Either way I wouldn't worry about unbolting just those two. Just don't forget your sealant.
Old Jun 13, 2007 | 11:49 PM
85ta4bm's Avatar
Car: 85 trans am
Engine: 350 4bm TPI
Re: vacuum thingy
okay so, i can take those 2 bolts out 2 put the bracket back on in order 2 bolt up the egr vacuum soleinoid, so where do i put the sealent (the intake got put on like a year ago) the only thing i can think of is thread sealent...
Old Jun 14, 2007 | 07:04 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: vacuum thingy
On the intake manny bolts that you're pulling out. Use a sealant with Teflon.
Old Jun 19, 2007 | 03:00 PM
85ta4bm's Avatar
Car: 85 trans am
Engine: 350 4bm TPI
Re: vacuum thingy
Thanks all
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
