ATTENTION: ALL TPI WIZARDS LETS SEE WHO CAN GET THIS ONE.
OK its an 88 GTA check my sig for mods but here are the simptoms. Simply put, its flooding the s@#t out of the cylinders. I feel that I have done everything humanly possible to fix it but no dice. All I keep getting is a code 33. I installed a new MAF checked all the wiring but it still wont idle or run correctly. I have also replaced the CTS,O2S,ECM,distributer,wires,3 sets of plugs, and changed the oil 3 times because of excess fuel in it. My injectors went in fine into the intake and I dont feel they are binding. My timing is at 8 BTC and fuel pressure is at 42psi with the vacuum line conected. When I change the plugs it starts right up and sounds good for about 1 minute the begins to missfire. Lets see who gets it right.
88GTA 5.7(under construction) ATI Procharger,58mmTB,ported plenum,SLP runners,Edelbrock HI-FLO base.ported heads,1.5RR,210/220/480 compcam,AFPR,SLP1 3/4 headers,3.70 gears,Eibach drag launch,Lakewood LCA`s, Nitto drag radials.
I am using an FMU but the problem is at all RPM levels even when the FMU is inactive at idle. I dont have a custom chip but all my mods were based on running a stock PROM. I know I will greatly benefit from a custom chip but at this time i havent ordered one.
ck the fuel pres.regulator see if raw fuel is being pulled into the vac line into intake.its possible the diapham has a hole in it..............
ck the TPS with a scanner.....remember those injectors are turned on by a ground in the ECM ....ck to be sure the two ground wires(one for each side of injectors)is not grounded anywhere....i doubt the cold start injector sticking open could dump enough fuel to cause this....i hope this helps
87GTA,350,Auto,MAF screens removed,K&N,modified air intake,ADSchip,3:73s,3inch cat back Flowmaster,TPS.54,Bosch Plat plugs,base timing 6BTDC,Bilstiens in the rear....,don't let yer meat loaf
[This message has been edited by RP1987GTA (edited October 12, 2000).]
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Its your injectors binding and staying open. This is a very common flaw of edelbrock Bases. Put a washer under each fuel rail bolt so the injectors arnt too tight in the bore.
TPS is at 50 and the diaphram is new. As I stated before my injectors went in fine but at this point ill try anything. Let me do the washers and ill let you know how it goes.
David G.
David G.
take a fuel press gauge and see how fast those injectors leak down at shut down...and if its leakin ...where the fuel is going ..i'm not familar with the edelbrock base ie tight injectors in the bores...but if thats it you should be able to ck it quickly with a gauge...
Transformer i think MKcos is referring to as you tighten down the four fuel rail bolts the main body of the fuel rail holding the injectors forces the injectors too far into the intake crushing them ...causing them to bind...he wants you to put the washer under the fuel rail to space the rail up farther...thus reliefing the pressure
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
TFMR, have you by the by swapped out the two MAF relays? Also does the rich condition happen all the time or only at idle - off idle? What about WOT?
Car: Formula
Engine: 6.0 LSX
My friend and his friend had the SAME Problem and the washers fixed it. I bought the Edel Base too and when I put it on I am just going to put the washers there too just in case.
i am one of the 2 people mkos1980 is talkin about.. first i would hook up a fuel pressure gauge and turn the key, the pressure should go up and stay at whatever psi you set your afpr too.. IF IT DOESNT then your injectors are grounding out becasue of the Edelbrock intake.. put washers under the fuel rail where it gets bolted down. Funny thing is i too have a code 33..??! read this---> http://www.nethirdgen.org/ubb/Forum11/HTML/000286.html
1988 GTA Trans Am 350tpi: 42k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, ignition module, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass
Future mods: Edelbrock tes headers, transgo shift kit& corvette servo,1.6 roller rocker arms, flux capasitor(to make time travel possible)
CAR NOT RUNNING AFTER INTAKE INSTALL!!
[This message has been edited by ron rizzotti (edited October 12, 2000).]
K&N: filtercharger
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If all else fails, change your temperature sensor. My firebird's temp sensor went south, and it would flood the **** out of the car and wouldn't start.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
I'm about 99% sure that it is your cold-start injector. The reason for that is I had this exact same problem happen to me about two years ago. I had the runners off, and when I put the CS injector back in I cut the o-ring some how. That one injector was dumping enough fuel into the cylinders that a few of the plugs couldn't even fire because there was so much fuel in the cylinder. It took me forever to figure out what it was when it happened to me.
Black 88 GTA L98
!Airbox, !IAT, !MAF, !TB, !Plenum, SLP 1 3/4" headers, Dynomax Hi-Flo cat & cat-back, Corvette Servo
14.389 @ 95.2 mph, 2.001 60' {Before headers, new times coming soon)
Black 88 GTA L98
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
I knew it! It's the code 33 caper! I have the same problem...heh must be common for this time of the year, kinda like the flu. Although mine was fixed with a new MAF Burnoff relay...I hope....
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-Future:
-383 Stroker?
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Future:
-383 Stroker?
If the injectors are stuck or leaking it should be dieseling like a sob when you shut it off. The maf relays might be a good place to look. Or if the car is getting false air, But i think that will make it run lean. Oh well wish my car would run rich. If you get fed up with it can I have dibs on the procharger?
87z 383. mini ram tremec 5spd, funny gas, 1,3/4"headers. other stealth goodies.
Oh and 42 psi is high with the vacuum hooked up especially with a fmu. I was running 55psi for only a little while and it wasted 2 of my injectors. They started leaking bad.
Thanks for all the help till now guys. I havent done the washer because I still didnt have a clear understandidng of what "binding" was. But I get it know. What I did do was check the sound of the injector pulse. All but the 2 front drivers side injectors sounded fine. Those 2 have a low deep clicking tone while the others have the normal light tapping sound. Injector binding seems to be the culprit but we will find out tomorrow. Ill keep you up to date on my progress. Until then if anyone has any more suggestions please feel free to post them.
ok... its easy to swap relays, expensive sensors, check fuel pressure,leakdown etc.....But if your getting code 33,the mystery in most cases is an intermittant 5 pin weatherpack connector that connects to the maf. Specifically, the digital or analog ground. A new connector from GM will only cost $14. To test, use a DVM/Continuity tester: Unplug MAF, probe front female pin on plug, then go back a few inches behind plug and pierce wire to see continuity(do this for each pin). With test probes firmly attatched, wiggle connector and see if continuity is lost. Any suspiscions, change the plug.. warning, the wires on new plug are all white so make sure the wires go to the proper pin(reference old plug). Everyone is so quick to throw parts and money and unnecessary diagnostics at code 33 without understanding what sets it.Invest in a chiltons or helms service manual where code 33/and what sets it is explained.A bad regulator or injector/fuel system won't throw a code 33. PS ... Also check the harness @ the MAF relay in the same manner. I hope this info helps you or someone who reads it. This can be frustrating.
Car: Formula
Engine: 6.0 LSX
This post is like 6 years old lol If I was still struggling with this problem , it would be sold by now
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
roflmao!!!!!
but at the end he did say hope this helps someone who as had the same poblem. i guess it would help anyone who reads this thread.
Sanjay
Aug 12, 2015 03:41 PM
