roller rockers or not?
Old Jun 12, 2007 | 02:46 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
with the mods in my sig and a built tranny coming soon, and 42k original miles, should i consider 1.6 rr's, are they worth it in. im also going to be procharging soon i hope. so my question is- is there a noticible hp difference? which are better for my app 1.6 or 1.5 ? if anyone else has added them to a stock lb9 please chim in.
Old Jun 12, 2007 | 02:53 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: roller rockers or not?
on desktop dyno, adding a set of 1.6 rockers only netted about 3-5hp at peak RPM from the lift alone. Now who knows how much reduced friction would add? They do help the engine rev a bit faster.
Up to you if you want to spend the green.
Old Jun 13, 2007 | 10:13 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
come on, i see this mod in alot of peoples's sig, someone???
Old Jun 13, 2007 | 11:39 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
well , it's a better thing then stock ... But myself i would just get the 1.5's ...then add a cam with the lift you want .... it's easier on the valvetrain.
Old Jun 13, 2007 | 11:43 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
can you recommend a cam combo for me? keep in mind i will be adding boost.
Old Jun 13, 2007 | 11:53 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I could , but I am not really qualified to do that for you ...I'd be just regurgitating stuff I read here . but call up a cam company ...they can help ya for sure.
One thing you will find out is .... a cam for N/A and one for boost has very different properties . Like a N/A cam , you may want a tighter LSA ...and lots of overlap ( depending on EFI or carb or other stuff beyond me ) ...while witha boosted cam you want low overlap ... fatter LSA . Get what I mean ?
So , i would just leave the cam UNTILL you decide to boost it THEN get a cam for it .'
hope that helped
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
