how much power can i get???
Old Oct 12, 2000 | 10:26 PM
Artic White Z's Avatar
im replacing my 305 with a 350 and useing the same tpi and intake.. i already have a fuel reg. and i will get a chip for the computer and maybe slp runners for the tpi. what kinda power you think i can get out of the stock tpi with a build 350?
Old Oct 13, 2000 | 12:29 AM
Blade's Avatar
20 horsepower ? It really depends on what cam and heads you're going with. Don't even think about reusing the stock 305 cam and/or heads.
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Oct 14, 2000 | 10:59 PM
IrocManiac's Avatar
Don't use the 305 heads or cam you will choke the motor. I have heard of people running low 13's high 12's with the factory intake. However the factory base plate is the biggest restriction on the TPI motors. I would try to find an edelbrock or TPIS intake if you can afford it.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 15, 2000 | 11:23 AM
The only thing im using from the orginal engine is the tpi. theres no way i would use the same cam or heads. im probably going to run vortech heads.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
