how much power to expect...
Old Jun 14, 2007 | 08:56 AM
LoneStar666's Avatar
Car: 2005 Pontiac GTO
Engine: 364ci LS2
Transmission: 6 speed
Axle/Gears: 3.46
10:1 compression
383ci
64cc TBI swirl port heads
212/218 .444/.454 110lsa
Stock TPI
Hooker Long Tubes
H-pipe
MSD 8.5mm Superconductors
MSD Blaster 2 Coil
New Cap/Rotor/Ignition Module
67gph Fuel pump
i am thinking my car will put down like 270-280rwhp and around maybe 400ft/lbs at like 3000rpm...
has anyone run 350 TBI heads on a 383 TPI before?
Old Jun 14, 2007 | 12:47 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: how much power to expect...
The heads are the key to horsepower. With stock tbi heads you might well be right. With decent aftermarket heads I would expect a lot more horsepower.
Old Jun 15, 2007 | 02:52 AM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
yea ditch the heads and upgrade the tpi. with the tpi and the 383 you have one hell of a street motor. the tq numbers might be a little higher then what you think. but the hp number look about right
Old Jun 15, 2007 | 08:12 AM
Engine: 364ci LS2
Axle/Gears: 3.46
yeah im planning on getting different heads but later on down the road, they arent THAT big of a concern with me right now because the TBI heads were meant to make low end torque and a 383+TPI and these heads make one decent amount of torque...
id say right now im running a mid/high 13 with stock TBI heads/stock TPI and 2.73 rearend gears
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
