PAGING all TPI geniuses,, -------->
Old Oct 23, 2000 | 04:22 PM
rondubbs's Avatar
ok, guys , no more blue smoke form exhaust after adding "STop Smoke". Fuel pressure is staying(thank you jesus).
but.... after 10 minutes of idling, the car dies(its like it runs out of gas) and wont restart until it cools back down.. WHY??? i know i have a code 33, i have had this for a while,, you think the maf finally died?? what else can be, HELP ME.! come on guys my car has been out of comission since June! thanks to Mr. Edelbrock.
Old Oct 23, 2000 | 04:47 PM
RP1987GTA's Avatar
i can think of a list a mile long ...but two stick out in my mind...the pick up coil and ignition module in the dist, are a good place to start...also i've used a heatgun to track down suspected bad components...like fer instance with the engine running heat the dist with the heat gun....but be careful not to melt wiring
87GTA,350,Auto,MAF screens removed,195 thermostat,cold start injector UNPLUGED,K&N,modified air intake,ADSchip,3:70s,3inch cat back Flowmaster single outlet,TPS.54,Bosch Plat plugs,base timing 6BTDC,22 MPG and runs like a bear,Bilstiens in the rear....,don't let yer meat loaf
Old Oct 23, 2000 | 05:03 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
This is a shot in the dark, but maybe when the engine finally heats up and tries to switch to closed loop mode (using the O2 sensor) it shorts out or something. Or maybe your O2 is giving it a value that makes the ECM think that the engine is running way rich so it shuts of the injectors to compensate?
Just throwing out ideas...
Black 88 GTA L98
!Airbox, !IAT, !MAF, !TB, !Plenum, SLP 1 3/4" headers, Dynomax Hi-Flo cat & cat-back, Corvette Servo
14.389 @ 95.2 mph, 2.001 60' {Before headers, new times coming soon)
Old Oct 23, 2000 | 05:39 PM
BadSS's Avatar
genius - yep that's me alright - ha!!
Hmmm, could be a number of things unrelated to TPI (per say),, kinda like RP, one thing pops into mind is the coil could be shutting down,, either because it's going bad, or there is a ground problem. Have you swapped the dist. cap / coil or taken any grounds loose here lately?
[This message has been edited by BadSS (edited October 23, 2000).]
Old Oct 23, 2000 | 05:56 PM
rondubbs's Avatar
new accel cap and rotor,
new accel plugs
Old Oct 23, 2000 | 06:58 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
How many miles on your car and when is the last time your fuel pump and/or fuel filter been changed?
If your fuel pump has never been changed and your car has fairly high miles (over 100,000), it may be that your fuel pump is getting ready to die on you. Fuel pumps seems to die one of two ways: 1) periodic times of low power/stalling or 2) car just won't start. Next time you have a problem with your car stalling, try giving your tank a good wack and see if the car magically starts. If it does, your fuel pump is getting ready to die.
PS: Wacking your tank is not a sure fire way to get the fuel pump working either...sometimes it will give it a couple more "free starts"...sometimes its toast.
Old Oct 23, 2000 | 07:08 PM
rondubbs's Avatar
car has 43,000 original miles on it. fuel filter was changed maybe 3,500 miles ago. i dont think its the fuel pump.
Old Oct 23, 2000 | 07:20 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Hey Ron, next time it craps out after 10 min. try unplugging your MAF and then try to start it while it's still hot. See if that gets her to start. BTW, when you have this prob. does the engine crank and not fire, or does it just click? Also have you checked for spark when it won't start?
Old Oct 23, 2000 | 07:23 PM
rondubbs's Avatar
well, im up at school and the car is at home with pops,, so the info i gave is pretty much all i know,,, im thinkin maf,
could a bad coil do this?
Old Oct 23, 2000 | 10:32 PM
BadSS's Avatar
No offense meant here Ron,, just a stab in the dark,, but it happens though,, when you put on the new cap did you move your ground strap over for the coil, or make sure the ground wire for the coil had a good ground (depends on whose coil you're running). If that coil isn't grounded properly it'll act like you've described. However,,, if your lucks like mine,, it won't be something that easy!!!
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
gta90
Sep 15, 2015 04:00 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
