Will an LT4 cam work in an L98?
I'm looking into getting a new cam, now I've heard that the LT4 cam (not the HOT came but the normal cam) can work in an L98, but I've also heard that I would have to get a new ignition system?
What is better anyhow? ZZ4 or LT4 cam? At least for a mostly stock L98, that will eventually be made to run up to 5500 RPM or so.
Sean Casey
92 Formula-350
"You can never have enough speed, the faster you go, the faster you want to go" (some TV show)
Sean Casey
92 Formula-350
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Sean, I have the ZZ4 cam in my car. I love it, but I've also got my other mods too.
You should get new valve springs with the ZZ4 cam as the stock ones wont handle the lift. The LT4 stock cam will bolt right in, but you wont see as much of a gain with it as you will with the ZZ4. Plus I know you're going to do other mods too, and you will wake up the ZZ4 cam when do them.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
You should get new valve springs with the ZZ4 cam as the stock ones wont handle the lift. The LT4 stock cam will bolt right in, but you wont see as much of a gain with it as you will with the ZZ4. Plus I know you're going to do other mods too, and you will wake up the ZZ4 cam when do them.------------------
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
And to add to that... how would this cam work in a speed density LB9? The specs are something like 210/212 duration, .450/.460 lift, if I recall correctly.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
supposed 'peanut cammed' car (yeah, right)
Built on Wednesday
91 Trans Am WS6
Bright White
5.0 TPI auto
Trans Go shiftkit
Built on Wednesday
GM 203 210 446 449 476 479 115 LT4 stock ('96)
Thats the specs for the LT4 cam, with 1.5 and 1.6 rockers. I think it'd be ok for a 305 too.
Could you show the ZZ4 cam's number for comparision?
Sean Casey
92 Formula-350
Sean Casey
92 Formula-350
GM 208 221 474 510 505 544 112 ZZ3/ZZ4 crate engine
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
1988iroc350tpi
Aug 14, 2015 07:52 PM
