Injectors ????
Old Oct 25, 2000 | 04:06 PM
James117's Avatar
Injectors ????
Will injectors for a mustang or any other car work for an camaro?
Old Oct 25, 2000 | 06:46 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The Ford SVO injectors work on thirdgens. So do LT1 injectors, and other TPI injectors like Corvettes.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 25, 2000 | 11:55 PM
ProblemChild's Avatar
Yes and no. Yes they will bolt in place, will they actually work without problems, depends on the injector. Injectors are rated at lbs/hr. Stock 305 (5.0) Chevy and 302 (5.0) Ford squirters are 19 lbs/hr. 350 (5.7) Chevy are 22 lbs/hr. LT1's are 24 lbs/hr. Typhoon/Syclone 4.3 are 28 lbs/hr. Turbo Buick's stock are 30 lbs/hr. Thunderbird Supercoupe 3.8 supercharged rate 36 lbs/hr.
All of these injectors will fit in place of another, however, they won't all work the quite the same. For all intents and purposes, injectors are rated the same way. How many pounds per hour of fuel they will flow at a specified pressure. In this case the test pressure is 3 bar. 1 bar = 1 atmosphere, which is approximately 14.7 psi. The accepted test pressure is more or less 42.5 psi (there is a barometric difference that is taken in account).
Keeping whithin these parameters either with pressure, and/or pulse width is where the allowable injector size can be played with.
Hope it wasn't so technicall it bored anyone.
P.C.
Torque is KING!
All pray to the god of grunt! When ye thinkth ye has been whupped than shall ye meet the mighty Buick! For none can surpass her majestic power, and all will yet try. All pray to the god of grunt. For the King of torque has arrived!
1. 82 Camaro+ 1. 455" Buick+ 1. N2O plate = YOUR WORST FRIGGIN NIGHTMARE!!!
Da Problem Child
ProbChldR@aol.com
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
