With Edelbrock intake and AS&M runners, will 48mm tb be good?
Old Oct 19, 2000 | 10:35 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm asking this cause i'm low on cash and cant really afford another 300 buck item.
89 FORMULA 350 Edelbrock Cat-Back March Pulleys
Accel Cap ,Super Coil SLP Airfoil K&N Filter 180 stat , Fan Switch
Taylor 8mm Spiral Pro,TB Bypass ,Energy Sus bushings ,Hotchkis STB ,MSD 6AL ,Edelbrock TES's ,Hi Flo Cat ,Crane AFPR ,Shiftkit w/Hurst lockup ,1/4 time 14.2@98
Old Oct 19, 2000 | 10:56 PM
airdeano's Avatar
depending on your aspirations of what your wanting your car to do, is limited by how much air you can pass into the plenum. the stock 48mm (650cfm) seems to fair well. but in a truely performance aspect the bigger 52mm (750cfm) usually wakes up the throttle power curve. but remember that the more air you try to digest the more fuel is needed. and if the fuel curve isnt in the chip, your system will lacking in power. for heavily modified engine cases the 58mm (1000cfm) throttle body in just that, lopey cams, high compression ratios and gears. if you have the modified tpi setup you can always attach the 52mm later. its not a have to right now part. only thing to understand that induction isnt only the manifold, the heads, cam profile and compression all make sense when combined for a purpose.
airdeano
[This message has been edited by airdeano (edited October 19, 2000).]
Old Oct 19, 2000 | 11:06 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I just know the 350 RamJet and 502 one from GM have a 48tb and they seem to do fine. i guess i'll see what happens
Old Oct 25, 2000 | 12:57 AM
airdeano's Avatar
ummm they use the 75mm single barrel throttle body.
airdeano
Old Oct 25, 2000 | 08:31 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The new GM 502 crate motor uses a stock L98 48mm throttle body.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Oct 25, 2000 | 09:33 PM
airdeano's Avatar
jim,
you are correct, i was wrong about the 502
ram-jet it is an lt1/4 throttle body (48mm)
airdeano
Old Oct 26, 2000 | 05:15 AM
88IROCs's Avatar
Been re-reading Lingenfelter's book lately. Seems the reason he designed the SuperRam manifold with the funky layout is: at higher engine speeds the stock plenum has a hard time getting air to the front(passenger-side) runners. The air has to make an almost 90 degree turn to get from the TB to the frontmost pair of runners(not good). He kinda solved that problem by forcing the air to make a sharp turn to the rearmost runners. This probably creates a restriction(I don't know for sure, I'm not an airflow whiz), but it would equalize the airflow to all eight runners(very important). By my weird way of thinkin', it would appear that the stock TB may not be the restriction the aftermarket makes it out to be. Could be the best solution would be to have the runners all draw air from nearly the same place on the sides of the plenum. Move the driver's side runners forward, and the passenger side's back. Course lacking a foundry, a flow bench and a healthy R&D budget, I'll just have to file this under "Unproven Kooky Ideas".
Just for clarification, according to GMPP press releases:
The Ramjet 502 uses a stock L98 TB. Again this may be wierd thinkin' on my part but: for the cost of the Ramjet 502(around $8000 U.S., last time I looked(drooled)), and the amount of custom parts on that motor, I would think GMPP could easily have whipped-up a larger TB if they thought it would make a significat improvement.
The Ramjet 350 uses the LS1/LS6 TB. Probably packaging(more wierd thinkin') as the plenum is quite narrow, and using the L98 TB(if it could fit) would probably hurt flow due to the close proximity of the TB blades to the side walls of the plenum.
He who hesitates,... is lost!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Sep 17, 2020 08:26 AM
86IROC112
Aug 17, 2015 02:00 PM
mdtoren
Aug 16, 2015 05:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
