Temp gauge actin up HELP!!???
Old Oct 25, 2000 | 11:09 PM
91B4C jacob's Avatar
Im not sure if this belongs here or not due to the fact that its not just about TPI but here goes...
I was driving to work the other day and my temp gauge pinned I dont mean just climbed but shot up to what looks like 310 would be and it was fast if you would have blinked you would have missed it. I tryed taping on the gauge cluster and dash but it didnt help any. I turned the key off and took the key out (on the fly) restarted it and boom it was fine, back down to like 160. I have just put a coolent temp sender in it from NAPA. it did it agian today on the way home after pulling in the driveway I opened the hood (motor running) and wiggled the cuplure on the temp sender that didnt do anything I got back in and reved it up that made it come down a bit(300) but as soon as I let the gas back up,it went right back.
I dont know what the deal is Its not like low coolent or anything that would be a slow rise and the senders new?
oh ya one more thing When I poped the hood with the motor on none of the fans were on The gauge read like 310 and the computer didnt tell the fans to come on that tells me that the problem is not the sensor. Right?
help me Please
Ya sure it is just an RS
B4Cyaa
1991 RS B4C
Former Nebraska Highway Patrol Car 1 of 3
305 TPI
WC T-5
Four Wheel Disk Brakes
Only Options
Rear Defrost
Am-Fm Radio
Red-int White-exe
One BA Of A 350 In The Works
Mods
Dynomax Cat Back (to hold me over till I got the $$$ for the Borla)
best 1/4mile Run of 14.92@94.83
with 145,000 on her
Old Oct 26, 2000 | 08:12 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
The fans are gonna activate as per the fan cooling switch on the other side of the block - the switch between your #6/#8 plugs. It appears you have an erroneous indication caused by either your temp sending unit, wiring, or the gauge itself. My guess would be the sending unit. You say you changed it once already, got it from NAPA? Did you have the problem before then? If not, I would get a sending unit (sensor) from GM and nowhere else. I have heard, but I'm sure there would be many rebuttals on this, that you shouldn't use any sensors other than GM. So there you go - my $.02
KAM
Old Oct 27, 2000 | 12:54 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
ÄI had the same problem on my other car. I changed the sending unit and clean the connectors and the ground, never had a problem since that with the temp. gauge.
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Bubbajones_ya
Jul 6, 2024 08:32 PM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
corey8084
Sep 17, 2015 02:56 PM
