TPI on 400??
Old Oct 22, 2000 | 06:58 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
TPI on 400??
can i put a stock GM 305 TPI setup on my 400 inch small ?? i can get one complete and cheap. i don't know much about TPI though.my '82 Z28 will be glad to see the 400 torque i bet.
thanx,ANDYZ28
82Z 305 w/comp 270 magnum cam,holly.TH700R4 w/B&M holeshot 2000 converter,& megashifter. 9bolt 3.27 w/1LE rear brakes 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc
Old Oct 22, 2000 | 11:37 AM
Blade's Avatar
Yes you can... You wont see the full potential of the engine though. I'd get a better intake (edelbrock, accel, TPIS) and better runners at least (as&m). Also get a bigger TB although it's not imperative that you do.
Old Oct 22, 2000 | 12:06 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I agree with Blade, the stock TPI intake will need to be upgraded to increase its airflow, to get its full potential.
Also, I am inclinded to go with a different method of induction: Superram or Miniram, if you wish to go "fuelie". With a 400, you don't need the torque enhancing properties of the TPI system. It makes plenty of torque the old fashion way, with cubic inches. The other two systems will definitely make the 400 perform to its optimum potential.
Old Oct 22, 2000 | 05:53 PM
ANDYZ28's Avatar
Car: 1982 Z-28
thanks,blade and glenn.
i'll take your advice into consideration. but i don't have the money for the super ram or mini ram. by the way glenn i have been to kamloops many times.
thanx,ANDYZ28
Old Oct 26, 2000 | 07:10 PM
ragtop88's Avatar
Car: '88 Camaro ragtop
Engine: 379 destroker
Transmission: m6
Axle/Gears: 10-bolt/3.42
I agree with whats been said, and consider this. This past weekend there was a guy in a mid-80's Z28 running 10.3's at 131 mph all motor. He had a 406 with a Victor Jr converted to EFI.....thats hauling the groceries. He won the overall True Street competition and beat many a SC/bottled car.
I forgot to mention this was at the Bristol GMHTP EFI Nats.
Tom
'88 Ragtop 379 SuperRam/Haltech EFI
'64 SS http://home.sprynet.com/~ragtop88/main.htm
[This message has been edited by ragtop88 (edited October 26, 2000).]
Old Oct 27, 2000 | 12:42 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
That 400 will consume a lot more air than a 305, just make sure if gets enough fuel all the time.......
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Oct 27, 2000 | 02:42 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
As a budget option, check out my EFI page.
There's some relatively inexpensive tricks that can help out your TPI, such as reworking your 48mm throttle body to 52mm, porting the plenum AND the base, and adding aftermarket runners that are gasket-matched to the plenum and intake.
http://www.isthq.com/~dan/efi.html
camaro71633
Sep 1, 2015 10:24 AM
downsouthboy
Aug 29, 2015 11:29 AM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
