Stock TPI Plenum
Old Oct 19, 2000 | 10:29 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Stock TPI Plenum
Does anyone know if I replace the stock base and runners, weather or not the stock plenum will flow enough for around 450 hp, the way it is or ported?? I like the look of the stock tpi setup and dont want a mini ram or something like that.
Old Oct 19, 2000 | 10:34 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Go with the aftermarket intakes, AS&M Runners and 52 or 58mm TB.
Old Oct 19, 2000 | 11:09 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
He's asking about the plenum, if he changes his runners/TB to aftermarket. And yes, port the plenum to match the TB and the runners, and it'll handle lots of HP.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 20, 2000 | 01:16 AM
IrocManiac's Avatar
Those stock plenums are quite good it is the runners and base plate that you ahve to worry about. But you have that covered. I say go for it but get a 52mm throttle body.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 20, 2000 | 07:29 AM
Lounge Lizard 6's Avatar
A ported plenum should flow enough, but I hope you have plans for a lot of cubic inches if you are looking for 450hp.
Mike
'90 IROC-Z, 5-speed, ZZ4, Trick Flows
Moderator SEThirdgen
Old Oct 20, 2000 | 07:33 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Woops Sorry
Old Oct 20, 2000 | 11:16 AM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sweet guys thanks, and yes i have plans for enough cubic inches, 383 will be fine.
Old Oct 22, 2000 | 12:54 PM
SINNIM's Avatar
Try going to this web site www.TPIS.COM
They have some options for you for your runners if your not going to have it done yourself.
91 CAMARO Z28
350 5.7 TPI (L98)
108,000 miles still stock and running strong!
Old Oct 27, 2000 | 02:46 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I can gasket match the plenum and port it for $60, if you are interested.
see: http://www.isthq.com/~dan/efi.html
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
MantyZ28
16
Dec 21, 2015 11:02 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
