I want a bigger cam which one??
Old Jun 23, 2007 | 02:54 PM
hung4wheeler's Avatar
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
I want a cam that is going to have a lopey idle ''i just orderd my new exaust which is the hooker catback system from jegs my car has older style heads on which ones are they my 4 bolts go around the outside of the valve cover ..my question how big of cam can i go with out messing up anything??
where can i get noisey timing gears I want the one that has the blower whine
Old Jun 23, 2007 | 05:13 PM
Abubaca's Avatar
Re: I want a bigger cam which one??
Good choice on the Hooker, I love mine!
.....what engine do you have? The ZZ4 cam is a good match to to the TPI/350 cars. It lopes a little, but keep in mind you engine has to "NEED" the air that big lopey cam provides. It may sound cool, but you'll lose power if you over do it. The stock TPI/350 (L98) cam is pretty good for smaller 305 TPI cars.
Keep in mind most EFI cars use a knock sensor, and CAN NOT use those noisy gear drives you're talking about. The knock sensor hears them, and will mess with the timing.
Old Jun 23, 2007 | 06:24 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
check out the exhaust clip I have in my sig here . It's the ZZ4 camshaft ...edlebrock HI-FLOW TPI ( siamesed in 4 " deep ) forged pistons ( who cares I know) SLP 1 3/4 headers with 3" catback . I like it .... not alot of loap but it does sound good
Old Jun 24, 2007 | 10:00 PM
95Cam86Roc's Avatar
Car: 86 Iroc
Engine: LS3
Since the stock 350 cam works well in the 305TPI, if anyone has one that they want to get rid of then send me a pm n let me know. I have an 86 that i'd like to get more power out of.
Old Jun 25, 2007 | 11:44 AM
Abubaca's Avatar
In 86, I'm pretty sure all 305's were non-roller motors, and starting in 87 (first year of the L98) all motors were roller motors.
*edit*
Sorry for being brief. What that means is you need a flat tappet cam as opposed to a roller cam like the 87 and up L98 cams. That or you can convert your non roller motor to a roller. Not sure what all is involved. It might be cheaper just to pay for a flat tappet cam.
Jorlain
Oct 8, 2015 01:57 AM
tommy z-28
Oct 6, 2015 10:58 PM
Accerrito22
Sep 5, 2015 09:34 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
