what size injecters?
Old Oct 29, 2000 | 09:26 PM
blowen90ta's Avatar
mods in sig+ afr heads approx 10-1 comp,and should have a new cam by spring lt4 hot--or zz-9? currently pushing 6-7 psi boost--thinking 24svo's but have been told by some to use 30's will be burning a chip for the new injecters
NO FMU WILL BE USED-unless i cant get the mv high enough any other way
thanks pete
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
Old Oct 30, 2000 | 12:12 AM
ScreaminDeamin85Z's Avatar
talk to stece at spohn performance he can let you know. i would say 30's but i would look into to if first.
Old Oct 31, 2000 | 07:58 PM
blowen90ta's Avatar
anyone else?
Old Oct 31, 2000 | 08:26 PM
87Z-ya's Avatar
Go with thirties at least, I have the 24 svo's on my car and it starves for fuel. With a blower you should really have 30's and i would run the fmu unless you are doing your own computer programing.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 24lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.(stock 305 hypercrap chip), other stealth goodies.
Runs 14's all day long.
Old Oct 31, 2000 | 11:39 PM
airdeano's Avatar
with the 6-7psi boost 30# would be good.
but with no FMu id maybe look to 36-38# the
tuner will thank you for the pulse width...
plus on wot passes less likely on locking
the injector up. less duty cycles keeps an
injector happy. and you not going to split the
bank over 24#. maybe $60-80 more.
airdeano
PurelyPMD
May 5, 2016 04:57 PM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
mackjar66
Sep 14, 2015 01:17 PM
m00n420
Sep 11, 2015 02:39 PM
