Help me choose a cam for this engine
Old Oct 29, 2000 | 04:58 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
My engine just blew Friday and I'm going to replace it. I just found this engine and since I'm on a non-existant budget this seems the best way to go.
However, the cam is puny! Smaller than the stock one even!
So, help me choose a cam that will work well with this engine with a long runner TPI manifold (not SR or MR!). How would a ZZ4 or LT4 hot cam work with this combo?
Black 88 GTA L98
!Airbox, !IAT, !MAF, !TB, !Plenum, SLP 1 3/4" headers, Dynomax Hi-Flo cat & cat-back, Corvette Servo
14.389 @ 95.2 mph, 2.001 60' {Before headers, new times coming soon)
[This message has been edited by Scott 88 GTA (edited October 29, 2000).]
Old Oct 30, 2000 | 08:59 PM
MIKES 88GTA's Avatar
Hey Scott! I'm kinda in the same boat too!
(can't find the damn paddles!)
I'm going back with stock heads and base just realy hogged out,2.02/1.60 valves and the ZZ-4 cam with 1.6RR. This won't be an11sec car but high 12's should be near. Kevin91Z has the same basic combo and he gets 13.20's I believe.I called a PROM burning ad in the back of some mag and they even suggested it.If you do get a GM cam definately check out Scoggins Dickey parts online they have great prices.
Good luck on the rebuild!
Old Nov 1, 2000 | 12:00 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
For any of you guys that read the CorvetteForum board you'll know that I post there a lot and that I just pulled my 355 and put in a 415 in my 86 Vette.
The 355 was completely rebuilt last fall (got all the receipts too)and it has only a couple of thousand miles on it. I'm retired and don't drive that much anymore.
Anyway, I had all the good stuff done to it and it's for sale. I live in DeSoto, just south of Dallas so you can come by to take a look.
I will sell it short block, 3/4 or complete (complete less a TPS, IAC, Water temp sensors, distributor and water pump) $750/$1,000/$1,500 if you're interested.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
gta90
Sep 15, 2015 04:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
