Ignition Module Shorts out?
Old Nov 1, 2000 | 08:39 AM
PapeDawg's Avatar
As you might know my GTA has a mind of it's own about when it wants to start or not. I replaced the Ignition module in june and the car worked fine for 4 days and started to not start again, other thirdgen owners have replaced their modules and fixed the problem. My question is could my module be shorting out, or a loose wire somewhere? what would cause this to happen?
Old Nov 1, 2000 | 03:04 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
I've been fighting this problem for over a year now. I found out on mine that I don't need to replace the module every time it happens, but just unplug the wires to it for a few minutes. This apparently resets something (I don't know what, or if it's even the module resetting), and the car will start. You also might want to replace your ignition coil. Mine went bad and kept taking ignition modules with it.
Black 88 GTA L98
!Airbox, !IAT, !MAF, !TB, !Plenum, SLP 1 3/4" headers, Dynomax Hi-Flo cat & cat-back, Corvette Servo
14.389 @ 95.2 mph, 2.001 60' {Before headers, new times coming soon)
pjsparts
Oct 29, 2025 06:39 PM
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
TrevinE
Sep 14, 2015 03:20 PM
