FuelPresureRegulator - how does it work?
Old Jun 25, 2007 | 10:43 PM
wiggin's Avatar
Car: 89 IROC-Z
Engine: 383 stroker
Transmission: WC T-5
Axle/Gears: 2.77
I've got a fuel pressure problem (pressure to high) so i'm trying to trouble shoot my fuel system. I have an adjustable fuel pressure regulator and im trying to figure out how the whole setup works.
What i can figure is the fuel comes i pressurized out of the fuel rail from the hole at the center of the assembly, then the flat at the center of the diaphragm and pressed up against the hole by the spring, control the flow of fuel into the fuel rail. Then the vacuum line creates a low pressure on the dry side of the diaphragm increasing the amount of fuel allowed into the system.
If this is the case, then how does lowering the adjustable screw compressing the spring on the fuel pressure regulator INCREASE the amount of fuel flowing into the rail??
Any help would be greatly appreciated, im obviously missing something key in the setup and need to be pointed in the right direction. (note: them lowest psi i can get my rail to is 80psi, and is running to rich)
thanks
Old Aug 8, 2007 | 12:59 AM
wicho's Avatar
Car: CAMARO IROC-Z
Engine: 350 T.P.I
Re: FuelPresureRegulator - how does it work?
so you cant adjust the pressure did you like the regulating fuel pressure or did it come like that
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
