ATTN: Mini Ram owners
Old Nov 1, 2000 | 01:47 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Im getting a mini ram myself in december and would like to know what cam some of you guys are running with it? I was going to get a TPIS ZZ9 cam, or something maybe from Comp cams. (hyd. roller) Any suggestions?
Oh yea Im also getting Trick Flow 23* heads too!
Convertible, L98, Edelbrock intake, runners & TES, SLP cam, Thin Head gaskets, March underdrive pulleys, Fastchips custom chip, Accel 300+ ignition, Relocated MAT sensor, TPIS airfoil & AFPR, K&N airfilters W/ chopped airboxs, Dynomax high flo cat, Flowmaster exhaust, MAC subframe connectors, B&M shift kit & XMSN cooler and NOS!!
Old Nov 1, 2000 | 09:19 AM
87Z-ya's Avatar
My setup is in my sig.
87z 383,afr 190's, crane hyd roller(224/230-.509/.528,112 sep),Ported and polished mini ram, 24lb inj, 3.42 gears, strange 12 bolt, tremec 5spd, , 1,3/4" slp headers.(stock 305 hypercrap chip), other stealth goodies.
Runs 14's all day long.
Old Nov 1, 2000 | 10:39 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
As has been posted on this board time and time again, for the miniram to reallt shine, you need good flowing heads and a big cam.
I have fully ported sportsman II's with 2.08/1.625 valves
As for cam, 242/250 @0.050 with 0.657"/0.600" lift - solid roller
as I said, big cam
Old Nov 1, 2000 | 11:19 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
isnt the ZZ9 like a race cam for the track only? i though that the ZZ4 was more for street. I might be wrong though.
Old Nov 1, 2000 | 11:49 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Are emissions a factor over in GERMANY? I know that the TPIS ZZ-409 cam with 226/226 @ .050,.520/.520 @ 1.5:1, and a 112 LSA will also work well in that combo. You could try one of Comp Cams EXTREME ENERGY cams also.
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Old Nov 1, 2000 | 06:43 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
What do you think of this cam for my 383 miniram, 225/240 .525/.558 , 116 LSA.
Old Nov 2, 2000 | 01:48 AM
Randy92Z's Avatar
Engine: Miniram 383
No emissions here in Germany, but I only got a year left here, then its back home to Minnesota where Jessie Ventura got rid of the tail pipe sniffer test!! Nice fella hun? Thanks for the input guys.
Old Nov 2, 2000 | 10:26 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Hey Randy, Jessie is a hell of a guy. The only reason why I even mentioned TPIS is because I bought a ZZ-409 from a friend for $150. He had it in a 94 Z-28 with a 396 stroked LT-1 with MTI ported LT-4 Heads and intake. He made 415 RWHP and 410-420 RWTQ with this cam on motor, but wanted more so he installed a SOLID ROLLER. Another thing about this particular cam is, he had it specially ground with a 115 LSA, so he could spray it. It idled like stock, but screamed up top. I will be using it in a 383 with a MR, but not a NEW MINI-RAM unit from them. I would only get a used unit from the classified ads. I would definitely call Comp Cams and get one of their EXTREME ENERGY cams if I were you.
[This message has been edited by 88SS6SPEED (edited November 02, 2000).]
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
indygene
Sep 26, 2015 11:21 AM
09ave
Sep 7, 2015 06:03 PM
