Will these heads bolt up?
i want to bolt my 86 305 TPI system to my 79 350.
the casting number on the heads ends in 624.
everywhere i look says these heads got 2.02 valves. they DONT. i measured. anyway, will these work with my 86 intake?
[This message has been edited by GeneralHazzard (edited November 03, 2000).]
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
'86 tpi should have the older style intake bolt pattern so I don't think you'll have any problems. Even if for some reason your tpi intake is cut for the 87+ style heads, you can always notch the bolt holes and drop it on.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 160,000 miles, K&N filter
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ambainb
Apr 25, 2016 09:21 PM
355tpipickup
Aug 25, 2015 12:54 AM
