injectors
injectors
I have 3 sets of fuel injectors and I have no clue what they are off of. Can someone tell me with these part numbers what they are:
1) 5235302
2) 0280150901
3) 5235047
thanks for any input
1) 5235302
2) 0280150901
3) 5235047
cobrakiller
I tried looking up those numbers in an injector database/spreadsheet I created. I could not find anything on those specific numbers. However I can tell you the manufacturers if you dont already know them:
1) 5235302 - Based on the number format this is a Lucas brand
2) 0 280 150 901 - This is a Bosch injector
3) 5235047 - Another Lucas injector
Are you sure you posted those numbers correctly?
If you would....reply with the colors of these injectors and what brand/model and year vehicles they came out of(if you know).
I am going to add these injector numbers to my database/spreadsheet.
Mike
Mike
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
How about these numbers-17086545 GM also had N260. Could you look them up on your spread sheet?
Thanx, Don
Chronologically challenged. But still alive!
92 CAMARO RS
305 TBI 5/spd
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
Thanx, Don
92 CAMARO RS
305 TBI 5/spd
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
1) 5235302 - 87-88 350 injectors
2) 0280150901 - not sure, but it seems really familiar for some reason.
3) 5235047 - 1985 305 TPI injectors.
If your interested, here are some lists i have compiled.
http://home.epsb.net/~mstrembi/injectors.jpg http://home.epsb.net/~mstrembi/injectors.htm
Enjoy.
Mark.
Enjoy.
Mark.
thanks alot you guys.
you have been a big help.
I bought a TPI kit off of a guy and there was 3 diff sets of 6 injectors, so I haev six of each instead of eight.
were the 350 87-88 injectors a GM injector.
thanks again
thanks again
Dyno Don
I have a set of injectors with the exact same numbers(except for the N260 markings). They are '90-'92 5.7(L98) injectors which are rated at 22lbm/hr. The GM replacement part number is 17112286.
Mike
Mike
Super - Mike, Thanx alot that's a big help.
Don<<<
92 CAMARO RS
305 TBI 5/spd
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
Don<<<
92 CAMARO RS
305 TBI 5/spd
'69 camaro
BB/Lenco
1050 dominators
8.97-150+
Pump gas/no drugs
thejimsterz28
Sep 15, 2015 04:37 PM
