what to do for more power
Old Jun 28, 2007 | 10:21 PM
87_gta's Avatar
Car: 87 GTA / 87 IROC-Z
Engine: 350 TPI / 350 TPI
Transmission: 700R4 / 700R4
Axle/Gears: Stock
hey, now i got the 5.7l gta running right i need some opinions on what i should do to make her put out even more power things i have done to the car as of is: i have a custom cold air intake, air foil, headers leading out to a true dual exhaust which i will post pics of soon. removed the smog system. AFPR with the ford #24 injectors. What is the proper fuel pressure to run the car at with the fords and what other mods should i do that are priced within reason that will help the car. i do plan on changing the thermostat and i want to make both fans work together. whats a good way to do this and any opinions on other mods to do, thanks
87_GTA
Old Jun 29, 2007 | 08:44 AM
shocker89bird's Avatar
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
Re: what to do for more power
well you can always do a search fro TPI mods and see some of th things other people did. If you want to try doing some porting yourself i would suggest porting your upper plenum and stock throttle body for some small gains, bypass the coolant hose that runs through the throttle body, change all of your fluids to syntheitc, you can also run lower temp fan switches so that your fans turn on early to benifit the thermostat, msd ignition, too much too list.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
