Plug gap??
Old Nov 6, 2000 | 06:41 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Plug gap??
Well now. I have seen several folks talking
about increasing plug gap after improving the ignition system. I have a basically stock 350, with an MSD 6A and blaster 2 coil, I am currently running stock gap (.035) How much can I increase this, and what are the benifits??
Thanks.
Old Nov 7, 2000 | 02:53 PM
'89Formula305TPI's Avatar
Well, I opened those plugs up to .045" that was what MSD prefers with those mods, but I noticed nothing difference after re-gapped those plugs..
You should definately buy MSD cap&rotor and new set of wires, to carry new increased spark, I mean that your stock cap&rotor contact surfaces may corrode very easily with heavy spark your MSD proudces..
[EDIT] typos... hah..
'89 Formula 305 TPI T-5
Check out my car HERE!
[This message has been edited by '89Formula305TPI (edited November 07, 2000).]
Old Nov 7, 2000 | 07:15 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
A larger gap exposes more of the "flame kernel" of the spark to the fuel and promote more complete combustion. However, the larger the gap, the greater the resistance and the greater the possibility of a mis-fire and fouling of plugs.
Also, if your wires are a little old, the electricity may short through the wire since the electricity will find the easiest path to complete the circuit. This is when you can see sparks through the wires or notice arcing in the cap if you have a high voltage system. If your system does not have high enough voltage, it may just not fire.
I like .045" for most systems with at least 50,000 volts.
Old Nov 7, 2000 | 07:52 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Glenn is right. Don't overkill the ignition system. It isn't hard to get a stock system to jump a gap that is one inch long, BUT when you factor in the fact that cylinder pressures, variations in rich/lean, etc... greatly increase resistance, therefore limiting the gap size. If you have an ignition box and coil, it would probably be safe to run .045", but I wouldn't go any more.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
gta892000
Aug 11, 2019 11:16 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
