MAF relay differences. They are not all the same
Old Dec 17, 2012 | 11:03 PM
  #101
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: MAF relay differences. They are not all the same
Originally Posted by fastgascar
Bringing this one back, can someone please assist. I pulled a code 36 so I started poking around the relays, I have a 1988 Chevy Iroc Z 5.7 and I have these exact colors on my relays listed in the quote, however the relay I think is the fuel pump has part # 10094701(rectangle), the other two are 14089936(round). I have the fuel pump relay out of the car and the car still starts. I disconnected all three relays and the car starts, of course the idle is rough. If the MAF power and MAF burnoff relay are supposed to be different then, why do I have two of the same. These are factory? Never been taken out of the car. The car has been in my family the last 24 years, so I know it was never swapped around.
With all the relays disconnected, especially the fuel pump relay, the car shouldn't start at all. When the the key is turned, it energizes the FP relay, which will send current to the oil pressure switch that is "open". When you crank the engine, the oil pressure rises and "closes" the switch which will then send a continues current to power the FP. Without the relay, there is no power to the oil pressure switch. That is how my 86 IROC is wired. I'm not too sure how your electrical system is wired so it may be different.
Old Oct 9, 2013 | 07:59 PM
  #102
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Hey Chevy86, love the fact ur still helping out guys on a thread that was started in 07. That's Love!!!
Old Oct 19, 2013 | 09:52 PM
  #103
The_AntiPirate's Avatar
Axle/Gears: 10 bolt 2.73 posi
I just want to put it out there because I just fixed this issue with my car. I would not use these interchangeably. My car had the power relay and the burnoff relay swapped around, and with them connected like this it caused the D terminal on the MAF connector to be powered with 12v, ran like garbage, and threw a code 33. So there must be something different where the relay is switched internally as the problem was fixed by connecting the right relays to the right plugs.
This was a 1987 with a TPI 305, both relays were from OE parts from AC DELCO.
Old Oct 20, 2013 | 06:19 AM
  #104
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Originally Posted by resinlake
ok here, is one more question, who would be the best source for a replacement Maf Burnoff and Maf Power Harness ends/plugs? Mine have exposed wires and move around too much. I think that is half if not the whole problem I'm having with mine. Thanks
NAPA and o reilleys have the wiring plugs
Old Oct 20, 2013 | 06:30 AM
  #105
Car: 86 IROC
Engine: 5.0 TPI
Actually, yes, I just read the post. I should hit myself huh? .....There we go. No problem. No offense taken.
it shouldn't matter how old a post is.every day un suspecting people buy these cars .and THEN the trouble starts.the smart ones come to TGO looking for info for their particular TPI hell. the not so smart ones go from garage to garage HOPING to find a "technician" that knows about our cars .only to find that the techs are younger than our cars and NO body knows anything.when it comes to 3rd gen Camaros we appear to be own our own
Old Oct 20, 2013 | 03:11 PM
  #106
Well said.
If your gonna look for a mechanic, it better be an old guy. They more than likely know about old vehicles and the basics.
Old Oct 28, 2013 | 03:39 PM
  #107
Zeifer's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 408 LSx
Transmission: T56 Magnum
Axle/Gears: 3.73 10-Bolt Detroit TrueTrac
So what are the current part numbers for these relays? I'm having a fluctuating idle and car craps out at 3600. Switched the two relays and the problem went away for a little while.
Both my relays are the oval ones, part number 14089936. 1988 IROC, 305TPI.
Old Oct 28, 2013 | 08:53 PM
  #108
Car: 86 IROC
Engine: 5.0 TPI
napa & oreilleys both have the "pigtails" in question, however ,i must point out that they must be soldered in, NOT crimped. the idea being that theres less resistance/heat in a soldered connection than a crimped one
Old Sep 1, 2014 | 05:09 PM
  #109
Tri'all's Avatar
Car: would like to drive this 1987 iroc
Engine: 5.7 bored .030 over
Originally Posted by pandin
This info comes off the AutoZone Web Page
MR82
MAF burn off
Part Number: MR82
Weight: 0.154 lbs.
Note: O.E.M. #10038792, 10094701, 14078907, 14078979
Gp-Sorensen / Relay - Anti-Lock Brake
MR82
Gp-Sorensen / Relay - Fuel Pump
MR82
Gp-Sorensen / Relay - Throttle Control
MR82
Gp-Sorensen / Relay - Fast Idle
MR82
Gp-Sorensen / Relay - Mass Air Flow Sensor
MR82
Gp-Sorensen / Relay - A/C Compressor Control
MR82
Gp-Sorensen / Relay - Radiator Cooling Fan Motor
MR82
MR22
https://www.thirdgen.org/forums/atta...1&d=1216175175
MAF power
Part Number: MR22
Weight: 0.15 lbs.
Application: With 4 terminals
Note: O.E.M. #10067925, 14039663, 14073412, 14078915
MR22
Gp-Sorensen / Relay - Blower Motor Cutout
MR22
MR22
Gp-Sorensen / Relay - EFE Control
MR22
Gp-Sorensen / Relay - Air Pump
MR22
Gp-Sorensen / Relay - Upshift
MR22
MR22
MR22 Note: Optional
MR22
Gp-Sorensen / Relay - A.I.R. Control
MR22
MR5
Fuel pump
Part Number: MR5
Weight: 0.149 lbs.
Note: O.E.M. #14078902 (14078914)
Gp-Sorensen / Relay - Amplifier
MR5
Gp-Sorensen / Relay - Aux. Engine Cooling Fan
MR5
MR5
MR5
Gp-Sorensen / Relay - Anti Diesel
MR5
Notice all three will run fuel pumps (large inrush and large magnetic cutoff, EMF) , and the MR82 weights the most.
The MR82 has larger relay contacts then the MR22, and did not see the extra resistors in the GP relays.
any way any of you can give me a hand with my tps voltage issue? I'm not even to sure if i have all the right relays in their location and I'm starting to think i have two different halts of wiring harnesses :S
Old Dec 23, 2014 | 11:00 AM
  #110
silverstang84's Avatar
Car: 88 IROC
Hey guys, Im getting confused with all the part numbers for the different relays getting thrown around.. For my 88 iroc, what are the correct part numbers for my fuel pump,mass air power and mass air burnoff relays? Thanks
Old Jan 2, 2015 | 01:10 PM
  #111
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
Who sells relays these days that work?
Old Jan 2, 2015 | 03:31 PM
  #112
Car: 88 IROC
^ I'd like to know as well
Old Jan 2, 2015 | 09:28 PM
  #113
Car: 86 IROC
Engine: 5.0 TPI
I buy oreilleys relays, admittadely they last only a 8 month average . but they beat the hell out of auto zone and advance that fail or are the wrong ones right out of the box. BWD -671 MAF power, and BWD -3009 burn off. I cross refrenced these from the GM relay numbers. they work for 86-89 Camaro and trans ams.with the 8th digit of the VIN being "F". or as in the TPI cars. they are our best bet considering
Old Jan 3, 2015 | 12:14 AM
  #114
Car: 88 IROC
I'm assuming we can't get AC DELCO or GM relays anymore?
Old Jan 3, 2015 | 06:57 AM
  #115
Car: 86 IROC
Engine: 5.0 TPI
no, GM considers them obsolete
Old Jan 3, 2015 | 07:03 AM
  #116
Car: 88 IROC
Well, that's sucks
Old Jan 3, 2015 | 08:22 AM
  #117
Car: 86 IROC
Engine: 5.0 TPI
Well, that's sucks
ah, it aint all bad. the BWD select relays are pretty good. the trick is to not get fooled into being told that "MAF relays are all the same". they are NOT. and doing the research to make sure you get the correct relays for your application. we find that buying a quality MAF and relays is half the battle with a TPI car. it took quite a bit of time and effort to compile the GM part numbers for these components. IMHO its the only way to be certain
Old Jan 3, 2015 | 01:03 PM
  #118
Car: 88 IROC
That's what I'm trying to figure out.. I've read this thread but in still a little confused. What are the right lets numbers for my 88, 350 TPI iroc?
Old Jan 3, 2015 | 09:30 PM
  #119
Car: 86 IROC
Engine: 5.0 TPI
R-671 and R-3009 are the BWD part numbers. they work on any TPI car from 86-89. I do not recommend any other brand of relays ,although you may cross reference these numbers. I find I have tried them all, and I find BWD to be the highest quality
Old Jan 3, 2015 | 10:30 PM
  #120
Car: 88 IROC
Thank you sir. Those 2 number you have me are for the mass air power and burnoff relays?
Old Jan 4, 2015 | 12:07 AM
  #121
Car: 86 IROC
Engine: 5.0 TPI
yes, as mentioned they work on the 86-89 TPI cars
Old Jan 9, 2015 | 07:30 PM
  #122
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
I went to autozone and got PO#19844 for the burnoff relay and PO#010469 for the power relay. I'm sure someones gonna say these aren't the correct part numbers and I know that they aren't the best choice but they have worked fine for me with no issues.
Old Jan 10, 2015 | 09:54 AM
  #123
Car: 86 IROC
Engine: 5.0 TPI
let alone the best choice, they aren't even the correct relays. but ,hey its your money
Old Jan 10, 2015 | 01:39 PM
  #124
TylerSteez's Avatar
Engine: 383 stroker
They are working fine for me, and for thirty bucks I'm not gonna cry and complain if I need to switch, thanks for the attitude though
Old Jan 10, 2015 | 02:12 PM
  #125
Car: 86 IROC
Engine: 5.0 TPI
hey, im not tryin to be a bitc$. my goal here is to help. and if the mystery relays work for you ,great. im trying to share what I have learned with others who need advice and part numbers. nothing more .or less.
Old Feb 3, 2015 | 02:17 PM
  #126
Car: 88 IROC
Hey man. I just got my car out of storage and I'm tackling this relay problem.. I have a question. If the 88-89 cars had the one square relay,2 oval relays, how can the parts numbers you gave me work on 86-89?
Old Feb 3, 2015 | 05:35 PM
  #127
Car: 86 IROC
Engine: 5.0 TPI
I have seen different styles of them. its not what the housing looks like that matters. its what is inside that counts.and according to the GM catalog the relays from 86-89 are the same
Old Feb 3, 2015 | 07:06 PM
  #128
Car: 88 IROC
According to the pictures, these telays are the flat square type. My Maf burnoff and maf power are the rounded type. They're not interchangeable.
These are what my relays look like. Fuel pump on the left, mad power in middle, maf burnoff on right
Old Feb 3, 2015 | 07:41 PM
  #129
Car: 86 IROC
Engine: 5.0 TPI
while it is true that none of the relays are interchangeable. you have to rule out if anyone has moved things around previously. on the bracket . you can check this with a test light. you cant rule anything out as POs may have changed things around . your best and only weapon is going to be a factory service manual for your car. that and us here on TGO
Old Feb 26, 2015 | 02:33 AM
  #130
judoka_ca's Avatar
Car: Camaro IROC-Z28
Engine: 5.0/305
Transmission: 5 Speed
That;s not entirley true as the tread "say they are not all the same", but couple if the them are interchangeable depends on the year and type for example up to year 87 the Fuel Pump relay and MAF burn Off Relay got to use the same part number (GM PART#10094701) or BW R3009 where the MAF power needs BW R671 for the same year.(I have listed the correct parts numbers from different vendors in my previous post).... 1988 year still used the (GM PART#10094701) for the fuel pump relay, but has different oval shape relays for power and burn off and I believe some one said they were not interchangeable, but that I don't know
Old Feb 26, 2015 | 09:50 AM
  #131
Car: 86 IROC
Engine: 5.0 TPI
while its very good to post up the info you did. my point was that POs can and do some strange things. its best to not assume anything is correct until you check.
Old Sep 9, 2015 | 05:56 PM
  #132
Johnstonxj's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 3:90
Here's a picture from the 1988 service manual I have. I just ordered the part #10094701 burn off relay. However, like everyone said, these cars are different. Funny that this pic shows it different from others of the same year on here.
Old Sep 21, 2015 | 02:31 PM
  #133
judoka_ca's Avatar
Engine: 5.0/305
[QUOTE=Johnstonxj;5959862]Here's a picture from the 1988 service manual I have. I just ordered the part #10094701 burn off relay. However, like everyone said, these cars are different. Funny that this pic shows it different from others of the same year on here.
I agree 100% I have compared the few diagrams for Fuel, MAF-Burn off and MAF-Power relays and noted different collours going to different terminals all diagrams claimed to be for 5.0 and 5.7 TPI engines
I have 87 IROC-Z28 5.0 TPI 5 SPEED F body and my MAF power relay wires are in reverese order as previoulsy posted by scubbasteve..in post 19
I compared my MAF power relay wires and they go as follows
MAF POWER RELAY
A-RED
B-BLK/WHT
C-TAN/WHT
D-GRN
D-ORG
FUEL PUMP RELAY
A-BLU
B-BLK
C-ORG
D-N/A
E-ORG
FUEL PUMP RELAY
A-TAN/WHT
B-BLK/WHT
C-GRN/WHT
D-ORG 16Gauge
E-ORG 12
Could any one who has 87 IROC-Z 28 5.0 5speed confirm Their wires and terminals especially for MAF-POWER RELAY.
PO of my IROC removed the MAF power relay and cut the wires for some reason.
I bought an after market one and reconnected it all to their corresponding collours but the she doesnt drive quite right and now am not sure seeing all the different diagrams that all my wires go to their correct terminals
Attached Thumbnails MAF relay differences. They are not all the same-scan.jpg
Old Sep 21, 2015 | 11:45 PM
  #134
judoka_ca's Avatar
Engine: 5.0/305
yes I agree with you Rusty all the way my post was merely FYI only
Old Feb 22, 2016 | 08:25 AM
  #135
FireballXL5's Avatar
Car: 1988 FORMULA
Transmission: 4spd auto
Axle/Gears: standard
[QUOTE=rusty vango;5873574]I have seen different styles of them. its not what the housing looks like that matters. its what is inside that counts.and according to the GM catalog the relays from 86-89 are the same[/QUOTE
All though that might be true, still can't use it if the connector won't or can't connect to the relay because they won't match up. Common sense here.
Old Feb 26, 2016 | 01:57 PM
  #136
Car: 1988 FORMULA
All depends on the relays you want to install, some are different, if you want the choice of which ones you need, check Hawks 3rd gen.com
Old Feb 26, 2016 | 02:13 PM
  #137
Car: 1988 FORMULA
Look at the wiring, for one, two have 5 wires and one has 4, so one of the relays is not interchangable, as for as the different types of relays you might have to change the connectors to fit the relay, as one type might not be on the market anymore. Which is what I am finding out the hard way.
Old Feb 26, 2016 | 02:15 PM
  #138
Car: 1988 FORMULA
This is the same set up I have in mine the FP relay is rectangle while the MAF relays are the other type.
Old Feb 26, 2016 | 02:26 PM
  #139
Car: 1988 FORMULA
There is a difference in the relays if your using the same for both the burn off and power it will not run right
Old Feb 26, 2016 | 02:27 PM
  #140
Car: 1988 FORMULA
Auto zone does not sell these any more
Old Apr 4, 2016 | 12:19 PM
  #141
Zarathustra's Avatar
Car: 1987 Firebird Formula
Hey guys, can someone explain specifically what the difference is in the MAF power and MAF burnoff relays? I've repaired some funky wiring by the previous owner and I just used off-the-shelf 12V 30A electrical relays. I had no idea they would be unsuitable, I wasn't trying to cheap-out. The MAF sensor is working (it used to throw code 33 & 36) but now the burnoff cycle is not happening (still throws code 36). If I replace them with the correct relays I'll have to source the pigtails as well since previous owner had done unmentionable things to the relays/wiring. So anyway, I'd love to save $50 - $60 and a couple of hours of work if the debate about correct v. incorrect relays is more about superstition or originality than concrete electrical specifications.
Old May 7, 2016 | 07:05 PM
  #142
ramicio's Avatar
Car: '87 Flame Red/Carmine Red GTA
I don't know why the power relay needs that resistor in '87 but not on the newer years. The MAFs are the same.
Old Jun 16, 2016 | 10:48 PM
  #143
hilltop530's Avatar
Car: 1987 Iroc Z28 Camaro
Engine: 5.7 TPI
So, I've been going through my relays trying to fix a no start issue and, have a 4th 5 pin (only 4 wires on it) box behind the 3 relays on the firewall. It is mounted on a bracket that is directly behind the Fuel Pump Relay. Can't seen to find what it is in any of the books. Any thoughts?
Old Sep 3, 2016 | 02:10 PM
  #144
banksGTA's Avatar
Car: 87 GTA
Axle/Gears: 3.42 posi
Any ideas after replacing both relays and maf? Still getting code 36 and it idles ruff an typically goes up and down between 400-550 rpm while in drive. Thanks for any help.
Old Oct 28, 2016 | 08:31 PM
  #145
TA89TPI305's Avatar
#14089936 relay can be found as AC-Delco #15-8240
called 88-91 Corvette over drive relay.
Old Sep 19, 2024 | 06:53 AM
  #146
Henker's Avatar
Car: 88er GTA
elcam84 made a good research. I want to complement this with the following notes, measurements and calculations:
In my car (1986, LB9, 5lTPI) there were the following relays used:
10094701, 10078907 and 10067925. The engine is stalling, when hot; shows the SES 33 and 36.
First of all the differences between the relays are as follows:
10094701: coil-resistance 66Ohm, equal 182mAmps at 12V, 4 connectors
10078907: coil-resistance 58,4Ohm, equal 205mAmps at 12V, 5 connectors
10067925: coil-resistance 53,8Ohm (including the shunt resistor!), equal 223mAmps at 12V; additional resistor between "D" and "E" of 1kOhm, 5 connectors
10094701: Because of the 4 connector-circuit, it is the relay, which you can use ONLY for "Burn-Off" (or/-/or/bk/dkblu)
Actually you can use it also for fuel-pump, but then the diagnostic-aids won´t work (from the ALDL-connector)
10078907: This number hasn´t appeared yet in the threads, but the measurements say, you can use it either for "Burn-Off" or for "Fuel-Pump" (or/or/dkgrn-wht/blk-wht/tan-wht)
10067925: This is the relay with the resistors in it and is used as "MAF-Power" (or/dkblu/tan-wht/blk-wht/red)
What´s the reason for these resistors?
In electronic-circuits it is used to protect parts for destruction due to high voltage. So the shunt-resistors tries to protect the ECM, and the other resistor tries to protect the MAF-Sensor.
So better use this relay, if available, for the "MAF-Power"
If you are not sure or you´re never able to read the Part-Number: Take your Ohm-Meter and check the resistance of the connections. If the Ohm-Meter reads 1kOhm between "D" and "E" you have a "MAF-Power"
Furthermore there are other relays you can buy:
Nexpart offers a 14078915 as a "Fuel-Pump"
Rockauto sent me a "SH058" for "Burn-Off"
Cars & Stripes have the MAF-Power under 14-1307 and the 10094701 under 14-1306
Old Nov 3, 2024 | 02:07 PM
  #147
Simsalas's Avatar
So the thread means that the MAF burn of and MAF power relay are not interchangable.
On my 1988 Pontiac Trans Am GTA 350 TPI, there the same part numbers (7313 / 14089936; see picture). Bone stock.
Is this the correct configuration? I can't imagine that there are differences with the same part number...
Mark_ZZ3
May 24, 2018 01:02 PM
thunder57
Nov 7, 2015 02:28 PM
racereese
Oct 3, 2015 03:46 PM
