Cold starting prob.! HELP
Old Nov 16, 2000 | 05:52 PM
I2ROC's Avatar
First off the mod.'s
Summit TPI cam
World Torquer 305 heads
Ported plenum
SLP 1 5/8 headers
SLP catback
This is my wifes 86 305 IROC.
Before the upgrades, you could turn the key through the window and the car would start on
the first or second rev. when cold.
Now the car spins like the coil wire is unhooked but does finally start.
Then even after sitting for 5 or 6 hours it will start fine! Only starts hard after sitting overnight.
Any help out there?
Thanks, Troy
Old Nov 17, 2000 | 05:19 AM
Ski89Z28's Avatar
Lets start with the simple stuff.
Have you checked the timing?
Changed the plugs, wires, distribrutor cap and rotor?
Reset you IAC and TPS voltage?
Sorry not trying to be rude just need to know what you've done.
If that was done the maybe clean the injectors?
Good Luck!
Old Nov 17, 2000 | 07:59 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
You might check the cold start injector.
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
