TB Coolant Bypass
Old Nov 26, 2000 | 03:36 PM
HighHorseZ's Avatar
TB Coolant Bypass
Is this mod beneficial? I have my TPI disassembled right now to clean and considering doing the bypass. I understand the logic behind it, but wondering if it really makes a difference.
Thanks,
Mike
Old Nov 26, 2000 | 03:41 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Don't know if it does or not, but I would reccomend it while its off. Can't hurt (unless you live in real cold climates)
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Nov 26, 2000 | 04:25 PM
rondubbs's Avatar
do it,, it cant hurt .
i gained .9 and 10 mph on the 1/4 mile with this mod.
Old Nov 26, 2000 | 05:24 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
As GMTech said, it doesn't really hurt (unless you live in a really cold climate). I have a TB Bypass and I have had no problems in driving in 15*F temperature. But if you live in a climate that gets to just above 0*F, then you may wish to leave it connnected as it helps prevent icing in the TB.
As for performance gains, nothing noticeable except it helps retain that "cold engine" feel on a hot day. It stops the TB from getting heated up by coolant, but the whole TPI setup is a heat sink on its own. It helps the TPI to cool down quicker if you have a cold air setup for your air cleaner. But other than that, it doesn't do much.
Old Nov 26, 2000 | 07:40 PM
Monkie's Avatar
I did this about a month ago. Its really not worth it right now. I had some trouble with it. But like I said its really not worth it now because its gettin cold. So if I were you I would wait till about spring when it starts to get warmer. You will feel it more.
1992 Camaro RS 3.1L
T5 Manual 5 speed
Open Air Intake
Z-28 Exhaust
8.5mm MSD Ignition wires
TB Coolant bypass
Kills:
95 (****) Probe GT
94 Mustang GT
91 CRX (dont ask me why he raced me)
2nd Gen Z28 (350) haha to you V8 guys!
More to come
$750 L98
Feb 1, 2025 02:25 PM
sheachopper
Jul 31, 2019 11:27 AM
