SLP runners+Edelbrock base=cam??
so I got a great deal on those too pieces, I'm gonna port the plenum to the runners, and the runners to the baseplate and smouth out the casting a bit.
Any of you guys running this set up, what cam are you using?? I have stock 882 castings with about 9.25:1.
I'm looking to get 13.7 consitent 1/4 miles, I don't think the intake change alone is going to do that (from 14.6 ..hehe), but I figure the right cam and a 350 chip should get me there....
all suggestions are welcome ;-)
thanks
thanks
Please give us more info to work with
305 ? or 350
Auto or stick?
Headers?
Gears?
92 Z28 5.7 TPI AUTO 105k factory motor and trans.
SLP headers and runners, B&M 2400 stall, shift kit,LCA brackets, EBACH spring kit, NITTO'S, NOS
best 60ft 1.87 1/4 12.48 @ 110.81
305 ? or 350
Auto or stick?
Headers?
Gears?
ooopppss forgot that I don't have a sig yet...
Ok, I got:
355, 9.25 cr, roller cam (unknown but mostlikely the stock one), TES headers, 3" main, flowmaster, stock stall, shift kit, 58mm tb, ported plenum, 3.73's posi and still running my 85 ecm with 305 hypertech stage 2 chip.
Ok, I got:
mirage
It might be the 85 ecm or the 305 chip or both, but you should be closer to a 14.0 et with the mods you have.
I have the same set up but I ported my SLP runners and eliminated the holes divider on the plenum so it would match the runners. Cam wise, I have a CompCam Xtreme Energy Roller 510/520, but I must tell you that you really have to love your car to be able to put up with the choppy idle. I would recommened the grind before the one I have (I believe it's 495/503)
'88 GTA 350
Headers, catback, free mods, Xtreme energy cam, and intake pieces
13.51@104.27, but can run better as it is.
I just put a new 2100-2300 RPM TQ Converter. I hope a 13.20 or better
RAPTOR, the baddest bird on the planet
AIM HIGH!
'88 GTA 350
AIM HIGH!
Well the intake is not on yet, I'm still running the stock pieces. I'm debating if I should put my new intake this x-mas break or not. Would I see a big difference with JUST the intake, or should I wait this summer and get a cam for it and MAYBE some AFR Heads...I say MAYBE because I have to finish my 69 BB project.... Far as the ECM, it seems to be complicated to do the swap and no one sales a harness that would make the conversion a breeze...which sucks cause I know that with even a stock 350 chip, it would perform better...(I have seen guys running mid 12's on 87 ECM with stock chip)... and the car is my daily driver, so I'm not looking to go 12's either, but a RELIABEL 13.5 would make my day
The LT4 Cam or the Larger of the SLP cams sounds tome like it would be an ideal choice for your car.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc or 195cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
L98 TPI 350 (5.7L)
Hotrodboba400
Dec 10, 2019 07:07 PM
