could i do a small porting myself?
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Would that work? I mean like with a sharpie, outline the openings of the upper plenum and bore it out to the black mark. I just thought of it but im really tired and dont know if I just thought some dumba** thing. im good at machining things but i mean idlk if it takes some special tools or that wot help hp wise
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
Re: could i do a small porting myself?
I ported my plenum with a die grinder and carbide bits. Knock down the walls behind the throttle body, smooth/enlarge the tube holes if you want.
Do some work on the lower intake where it transitions from rectangular to round, thats a real bind spot.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Well that sounds good. But can i siamese my lower intake somewat easily?
mrestrictrplate
Sep 21, 2015 11:24 AM
gta892000
Sep 16, 2015 12:37 AM
