high rev startup problem normal?
Old Dec 4, 2000 | 01:39 PM
Reed's Avatar
I have an 89 IrocZ G92 305, 5pd and when I start it up, it sometimes revs up all the way to 2grand and back down to 750 and up to 1500 then to normal. Sometimes it stays at 2000 for a while then finally goes back down. Other 'rocs I've rode in don't do this. Could it be the TPS sensor or what? I don't think it is normal.
1989 Iroc-Z. 305TPI 5spd, G92 (230hp/300ft/lbs). 91-92Z28 groundeffects. Corvette Admiral Blue Metallic paint. Thermomaster chip, 160*stat & fan switch, Bosch +4 plugs, MAF screens removed, custom ram air, Flowmaster cat back, K&N, adj. fuel pres. reg.
72,000 miles. SWEET!!
Old Dec 4, 2000 | 04:46 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Why is this question in the History/Restoration section? Sounds like an engine question.
'91 GTA with TPI 350 & T-Tops. Just a few mods, if you want to find out just line up next to me at a stoplight!
Old Dec 4, 2000 | 06:36 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Blacksunshine is right. It has nothing to do with history or restoration. This post is being moved to the TPI board.
Willie
Old Dec 5, 2000 | 12:00 AM
Ski89Z28's Avatar
I had a problem simular to this but my idle level was at an average of 750rpms. I mean it would jump up to 1000 then back to 750 then to 800 then to 500 and so on.
Before anything is the car throwing out any codes? If not try the following.
Check your fuel pressure if you can to make sure that is steady.
Make sure your plug wires are good ... not burnt or shorting.
Then I would try to set your timing then reset your IAC and TPS voltage.
If this doesn't work, which it didn't for me, I would change the ignition control module in the distributor, if you have already changed the cap and rotor. This is what worked me.
Good Luck
Infested
May 22, 2018 11:56 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
db057
Aug 22, 2015 08:17 PM
mustangman65_79
Aug 8, 2015 12:07 PM
