What is the Proper way to adjust the IAC with an 58mm TB????
Old Dec 2, 2000 | 07:25 PM
Kyle F's Avatar
I need to adjust the IAC. the car doesn't seem to want to run right under 1000rpms, It does fine every where else. I can tell it is something to do with the Idle Air becuse when I let off the gas everything is fine until it gets down to like 1500 rpm and then it starts acting funny.
Kyle Felts
355 TPI
Old Dec 3, 2000 | 12:39 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
Have you tried following the procedure outlined in the tech section? I would think they're all the same regardless of what size TB you have on your car.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 3, 2000 | 08:00 PM
leirch's Avatar
Kyle,
I have the EXACT same problem, except the car won't idle under 1k rpms. i need to adjust what has been suggest. I'm going to do that very soon.
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Chrome Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
Old Dec 4, 2000 | 06:02 PM
irocz's Avatar
Car: '87 IROC-Z
leirch- what kind of chip are you running? I had to set my tps at .35v before mine (stock chip for now) would idle below 1000rpm. It fixed all my driveability problems. It's just a crutch though until I get something designed for my setup.
Old Dec 4, 2000 | 09:35 PM
leirch's Avatar
irocz, get this!, i'm running the stock 305tpi chip still!!!!
I need atleast a 350chip of some kind... i think i have a line on an 88 350hypertech chip that i might be able to copy to tide me over....
Old Dec 4, 2000 | 10:13 PM
irocz's Avatar
Car: '87 IROC-Z
Try setting your tps to .35v and see what happens.
Old Dec 5, 2000 | 12:14 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Stock TPS voltage should be at .54v +/- .08v
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
J-money
Jan 4, 2019 09:45 AM
86IROC112
Nov 27, 2015 09:54 AM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
