Easy way to make power on 86 305 tpi???RAM AIR??
Old Dec 1, 2000 | 12:51 PM
86IROCMIKE's Avatar
I already gutted the cat,what are some garage mechanic ways to improve performance,like taking out the maf sensor and whatnot,some cheap and easy ways to make it more efficient,any way to build a cheap reliable ram air sytem???Any links to advice will be well appreciated
86 iroc,canary yellow,fully loaded
Old Dec 1, 2000 | 11:04 PM
Stell1579's Avatar
DONT TAKEOUT THE MAF it is verry important to the car. there are many more things to be replaced besides that., a good catback, tuneup, port th eintake plenum and runners and intake manifold. in 86 yo uhave waterpump dirven fan? if so a switch to a electrical would do prety good. just search the boards there is some good info. check the tech articals aswell
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
Old Dec 2, 2000 | 01:41 AM
Mo's Avatar
Mo
make a homemade ram air, theres an article on it around here somewhere. Also, i dont know if you want to spend like $120 or so on a JET stage 2 chip, but my after the ram air, and catback, my friend put one in his 86 IROC and it made a noticable difference. Down the road you may need to replace it with a custom one, but for now, I'd consider it.
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Dec 2, 2000 | 01:42 AM
Mo's Avatar
Mo
put K&N's in too when you do the ram air
Old Dec 2, 2000 | 07:46 AM
theformula's Avatar
Gut the air box (cut the sides off) and replace your ac delco with a K&N ($30). Then run a piece of tubing from the snorkel on your airbox , to the inside of your fender. OH yea, you have to relocate the carbon cannister. I put mine sideways and put it behind the passenger headlight so I could face the air filter towards the inside of the passenger fender.
Gut your MAF. DO not remove it. Take off your plenum, if you look inside there is a wall behind the opening. Take the wall down with a dremel and some sanding pieces.
Bump your timing to 10* (remember to remove the est wire. Its a brown wire over your heater box). Adjust your TPS sensor, dont go over .62 (TPS sensor is the orange plug by your throttle body). Take out your spare tire and jack from the car.
You will notice a nice increase in performance for only $30. Next mods should be in order : catback, headers, airfoil. Summit sells a cam package for your year since you dont have a roller cam. It says it adds like 40hp.
Dont buy a Jet chip. Get a custom one burnt. Ed wright does a good job for $350 (www.fastchips.com) A lot of people will tell you to burn your own, if you have the knowledge to do so then do it. Otherwise custom chips work just fine.
I think thats all.
Whens the last time you did a tuneup? Cap, rotor,pcv valve, fuel filter, air filter, spark plugs?
'92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,Crane AFPR (47psi),MSD6AL,AC delco cold plugs, Bosch O2sensor, homemade cold air,K&Ns,3:73s,JET fan switch, Macewen white face gauges
Old Dec 2, 2000 | 01:31 PM
Guest
Guest
Posts: n/a
Somewhere in your plans, you will have to change the cam. The 86 TPI has the dreaded 'peanut' cam, which is doing no favors for performance at all.
Old Dec 5, 2000 | 04:09 AM
F22Raptor's Avatar
What's the peanut cam? What are the specs. on it?
jaridjohn
Jul 8, 2024 03:49 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
bryan623
Aug 10, 2015 11:33 AM
drathaar907
Aug 6, 2015 04:20 PM
