Gutted Airboxes
Old Nov 30, 2000 | 08:55 PM
BlueIrocZ's Avatar
Gutted Airboxes
I have heard of many people on this board gutting their airboxes and I have always been curious on how to do it.. Does anybody have any tips or experiences on doing this? Thanks for any help....
89' 5.7L TPI Auto IROC
Flowmaster, high-flow converter, SLP headers, B&M console megashifter, MSD 6aL, airfoil, K&N's, Bosch Platinum +4, 8.8 wires, blah blah
Old Nov 30, 2000 | 09:49 PM
Yarnboy's Avatar
Use a saw and cut the bottom out..I hope there isn't a science to it..I just cut out the bottom..I gained .7 MPH in the quarter mile from it. Good luck
-Red '88 IROC 5 Speed 305 TPI w/3.08
-Dual Friction Centerforce Clutch
-Accel 300+ Racing Ignition
-Accel 300+ Pro Sleeve Plug Wires
-Accel U-Groove Plugs
-Flowmaster Force II 3 Chamber Cat Back Exhaust
-Hypertech Chip
-Hypertech Airfoil
-Removed, Then Re-installed (out of fear) MAF Screens
-Gutted Air Box
-Best E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 MPH 93.91
-Best 60' 2.17
Old Dec 1, 2000 | 10:02 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Yarnboy, next time your at the strip, try removing your air filters too. I take my K&N's out and pick up around 2 MPH from just this. Oh yea, my air boxes are gutted too.
Convertible, L98, Edelbrock intake, runners & TES, SLP cam, Thin Head gaskets, March underdrive pulleys, Fastchips custom chip, Accel 300+ ignition, Relocated MAT sensor, TPIS airfoil & AFPR, K&N airfilters W/ chopped airboxs, Dynomax high flo cat, Flowmaster exhaust, MAC subframe connectors, B&M shift kit & XMSN cooler and NOS!!
Old Dec 1, 2000 | 04:56 PM
Dan87IROC-Z's Avatar
You just simply cut everything out that there is, so when you take out the air filters, all you can see is the ground and the fog light tubes.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Dec 2, 2000 | 02:30 PM
Slow88RS's Avatar
<quote>Yarnboy, next time your at the strip, try removing your air filters too. I take my K&N's out and pick up around 2 MPH from just this. Oh yea, my air boxes are gutted too.</quote>
Do you have the ram air setupd, if so...aren't you worried about rocks and whatnot falling in your engine? I wouldn't ever remove the air filters, it catches all the little stuff to prevent engine damage. If your just taking them off, create a ram air for about $30 and I can almost guarantee a better peak in performance.
90 Iroc LB9 5spd G92
Dual Cats, 3.42 Borg Warner w/Posi, TPIS Airfoil, K&N, 160 Thermo, Mobil 1 Extreme Formula 0W-30 Synthetic Motor Oil, Home Made Ram Air, ACDelco Plugs, 8.8mm 300+ Accel "Race" Wires, Accel Cap And Rotor, Ported and Gasket Matched Plenum, TB Coolant Bypass, Advanced Timing To 10 BTC
Best ET(Not Corrected): 14.4 @ 94mph with 2.022 60ft
My 3rd Gen Web Page
Old Dec 2, 2000 | 02:45 PM
BlueIrocZ's Avatar
Thanks for your input everybody and i am about to go out and gut my airbox... how did you guys make your ram-air and what gains did you get from it?
Old Dec 5, 2000 | 05:32 AM
Randy92Z's Avatar
Engine: Miniram 383
Well think about this, when your at the track and you take out your filters your only driving like 5 mph around the track until you get into the staging lanes, right? Your not gonna suck up rocks into your engine. Maybe a little more dust if anything. Its a free mod. Save the 30$ for track money, for more testing.
Linson
Oct 24, 2025 02:00 PM
Jeremys87
Jul 14, 2022 09:08 PM
pico87iroc
Aftermarket Product Review
Dec 11, 2001 08:00 PM
