z28 duel air cleaner on a firebird?
Old Dec 6, 2000 | 08:51 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
has any one ever put a z28 duel air clearner on afirebird?i'm swapping my tbi for a 89 maf tpi and want this set up
1991 banditt2 firebird #130of#600
Old Dec 6, 2000 | 09:39 PM
Tonyrodz's Avatar
Transmission: auto
Did the z28 have a carb? If it did then it won't work. On tpi setups the air comes from the air canister that's near the pass side headlight--no way you can run a carb air cleaner on a tpi. Now if the Z had tpi in it, w/the dual air cleaners I'm not too sure about that.
Anybody else?
Old Dec 6, 2000 | 09:48 PM
91banditt2's Avatar
Engine: 5.7 HSR
the z28 air cleaner i'm talking about is for a tpi maf that goes over the radiater shroud and around the hood latch.they didn't come on the firebirds and want to know if any one has put one a firebird?
Old Dec 6, 2000 | 11:27 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
It won't work right. First you'd have to cut the $hit out of that metal in front of the core support. Plus you'd lose power b/c I think that's blocked off somehow. Trust me, there's a reason Pontiac didn't use that setup b/c it cost them about 10hp vs. the IROC. Just get a SLP cold air kit or you can run a big *** K&N cone...that will work just fine.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 8, 2000 | 03:54 PM
Ron Mullins's Avatar
Check out my setup. Follow the ram air link.
http://www.geocities.com/91formula
91 Formula WS6
Home Made Ram Air,K&N Air Filter,Air Foil,
Ported Plenum,Underdrive Crank Pulley, Crane AFPR, Edelbrock High Flow TPI Runers, Holley 19lb Fuel Injectors, SLP Headers, SLP Y Pipe & Complete SLP 3" Exhaust and Muffler, High Flow Cat, Mobil 1 Oil, Hotchkis STB, Spohn LCA's and Panhard Bar and other polyurethane goodies.
Http://www.geocities.com/91formula
Add your 91 F-Body to my 91 F-body's Links page, or be added to my F-Body Links Page.
Old Dec 9, 2000 | 10:12 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Absolutely not. I tried it when I did my TPI swap, and I didn't want to cut all that metal out behind the front fascia, not to mention, you will have to cut the air boxes to clear the turn signal lamps.
On top of that, the hood will interfere where it goes over the radiator support. You will have to cut out the bottom of the hood.
To give my car "cold air" here is what I used:
1) '88 firebird snorkel (90* elbow)
2) 3" exhaust w/ about a 45* bend, primed, basecoated and clearcoated,
3)Cone filter w/ 3" fitting on end
4) Plastic sheeting and weatherstrip
To let you know how it worked, I used a scantool to check temperatures (I relocated the temp sensor down to the filter) the engine temp was 210*F and the air temp was reading 66*, so it seals off pretty good.
Here is what it looks like:
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[This message has been edited by GMTech (edited December 09, 2000).]
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
