MAF SENSOR
Old Dec 6, 2000 | 12:07 PM
87uroc's Avatar
MAF SENSOR
I need a new MAF sensor. An original BOSCH for my 87 TPI 350, IROC, costs 600.00 canadian. Does anyone know of higher flowing/better MAF sensors that can be purchased in Canada or mail ordered from the States.
Thanks!
Old Dec 6, 2000 | 12:55 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
You could try TPIS. They have some. Their address is www.tpis.com.
Hope this helps.
86' IROC-Z
5.0L TPI
Stock(for now)
Old Dec 6, 2000 | 06:43 PM
rondubbs's Avatar
unless you have a lot of mods and like 500hp, you dont need a high flow maf.. get one cheap off of ebay.
Old Dec 6, 2000 | 08:17 PM
Drewcifur's Avatar
Car: 1989 Firebird Formula
Engine: 350 ZZ3
Axle/Gears: Stock
I don't know about anyone else but i've had a lot of problems with my modified sensor. I plan to change to a super ram eventually but for now i'm just gonna keep my stock sensor on cause i've replaced two. One i ordered modified and one i did myself. And you can't send em back to gm after the screens come off. Like he said unless you have around 400-500 hp or so i don't think it's worth it. But thats just my opinion.
89 Formula
Edelbrock Headers+
Catback system,Torque Converter,Rebuilt Trans,B&M Megashifter, K+N air filter, Accel Distr. Module, MSD coil,New Fuel injectors with adj. regulator, ECM with performance prom,and a Crate ZZ3 350
Old Dec 6, 2000 | 09:42 PM
Tonyrodz's Avatar
Transmission: auto
What about that one made by Wells? Supposedly outflows the original GM one-unmodified! You might want to look into that.
Old Dec 7, 2000 | 12:40 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Go for the Wells/COnrad SU-145 MAF unit only 160 $ at World Discount in Buffalo
(800)288-6728 extension 115 talk to Tom Martin
www.wdautoparts.com
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Old Dec 7, 2000 | 05:45 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Thanks!
How about updating to the 1990 ecm?. yes it's work, but allows updating what you have to MAP, and their are millions of good used MAPs around. The MAF situation will just be getting worse
Old Dec 9, 2000 | 11:52 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Thanks!
What is wrong with MAF? If a lot of mods are in the future why convert to SD now? That doesn't make sense...replace the MAF with one of those Wells MAF sensors.....then once u are done with your major mods convert to SD if u wish....to do it now would be foolish.....why have to spend $$$ on a new chip all the time? Why spend A LOT more $$ on converting to SD when u can get a new MAF a lot cheaper?
89 GTA
Originating memeber of the SJNEP crew
Rice....it's whats for dinner
check out the car here:
http://www.hometown.aol.com/clarkemustgonow
Tony
Old Dec 9, 2000 | 12:02 PM
leirch's Avatar
fly89gta, What i think grumpy is getting at is that by updating you will save ALOT of money compared to buying new MAF sensors all the time... i mean damm! a new MAF is what 300+? You can get a new MAP sensor for like 50bucks right?
Another reason grumpy says that is because he makes his own chips and is probly pretty damm good at it by now. But i also understand what your saying about the chip factor because i don't have the knowledge or equipment yet to do it myself.
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Chrome Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
Old Dec 9, 2000 | 04:30 PM
fly89gta's Avatar
Car: 2018 Camaro SS
lierch i understand what he's saying but how often do MAF sensor's go? i'm now on my third 3rd gen and have only had 1 MAF go on me....plus don't u have to get a SD plenum? i think they are a bit different(don't quote me though cause i'm not 100% sure). If u can burn your own chips than thats definatly an advantage.....and no not all MAF's are $300...thats a bosch one....Wells sells them for around $160 and they flow more than the bosch's
Old Dec 9, 2000 | 09:08 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
I'd rather have to replace my maf every few years (they can be had w/ lifetime warranty) than have to burn a new chip every time I do another mod.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 9, 2000 | 10:23 PM
Guest
Guest
Posts: n/a
Never had my MAF go bad... On 3 different cars too. There is nothing to 'deal' with when running a 165, it just requires some thought rather than just throwing your hands in the air and running to a different system that has its own limitations as well.
BumpaD82
Feb 26, 2016 02:57 PM
sleprock
Oct 1, 2015 09:39 AM
Racerx974
Sep 19, 2015 10:16 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
earlpote
Sep 12, 2015 11:55 AM
