What to do with a 85 305 TPI engine
Old Dec 10, 2000 | 04:54 PM
Coolcars's Avatar
I just got an 85 IROC from a kid that just rebuilt it in auto shop class, and didn't do a very good job. I'm going to pull it and go thru it again. What should I do with it? I am probably working with a $1000.00 budget.
2E,87 Formula 350, 4 other Camaro's & 3 Firebirds to fix, Drive, or sell.
Old Dec 10, 2000 | 05:56 PM
ede's Avatar
ede
the basics, rings, bearings, oil pump, timing chain new rod bolts. bore it if you have too and new pistons. for up grades i'd look at cam, heads, and headers. AFPR will help. i'm sure i've exceded your budget, but you get an idea.
ICON Motorsports
1st & 3rd
Old Dec 10, 2000 | 08:35 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
Get a cheap reman. 350, some 22lb injectors, and a good chip.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Old Dec 11, 2000 | 09:24 AM
Coolcars's Avatar
Thanks for the responses guys, Does anyone else have some specific ideas? All answers are appricated.
Old Dec 12, 2000 | 12:45 AM
irocz's Avatar
Car: '87 IROC-Z
if you're sticking w/ the 305, the best thing you can do for the engine is get a good cam and some 305 torquer (I think that's what they're called) heads. You should still come in under budget.
Old Dec 12, 2000 | 08:20 PM
mtx28's Avatar
summit sells a rebuild kit for 5-600 bucks, to replace all of bottom end, and im sure the parts are of good quality, and even if they do break, summit has a great reputation of standing behind their products. get a flat tappet cam(like yours is already) for another 100 bucks.
Vintageracer
Jan 10, 2020 05:33 PM
R3500
Aug 17, 2015 12:16 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
