how much lift can the stock valve springs handle
Old Dec 12, 2000 | 08:59 PM
theformula's Avatar
Bought 1.6 roller rockers. Will the valve springs need to be changed on a 1LE/G92 cam?
91 Formula
305 TPI 5speed
1LE package
Custom cold air intake w/K&N, SLP airfoil, ported plenum, Crane AFPR (47psi),MSD6AL, Holley 9mm Annihilator wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, Slp 1 5/8 headers and catback (all stainless steel!), 3:73s,JET 195* fan switch, Macewen white face gauges, Intellitronix Digital Gauges
Stock throttle body,intake manifold,cam, and heads.
Old Dec 12, 2000 | 09:20 PM
Dan87IROC-Z's Avatar
I've been told they can handel .500 lift. So I'm not changing them right away when I get my LT4 Cam because its life with the 1.5 rockers is .492.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Soon to come: LT4 HOT Cam, Air Flow Research 190cc Heads, 2800 RPM Stall Converter and SLP 3.70 Rear End Gears.
Old Dec 17, 2000 | 06:00 PM
ede's Avatar
ede
i believe you'll need to replace your springs. i was thinking the number was .46 or something like that, close to .5 but not quite.
ICON Motorsports
1st & 3rd
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
anesthes
Aug 8, 2015 09:37 PM
