IAC questions with a bigger cam?
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I am building a L98 for my GTA 5-spd. I'm using a ZZ4 cam, headers, exhaust, K&N,!TB, Coil, Chip, ported plenum, and a few others. I thought I heard that with a bigger cam you had to adjust the IAC, TPS and something else. I have the Speed Density TPI also, is it more "finicky"? Well, I appreciate all the help! Thanks
'91 GTA:5.0-5-spd, chip, K&N,Flows,Coil,Air Foil, 350 soon to come!
'39 Chevy coupe
'52 Chevy p/u
'39 Chevy coupe
'52 Chevy p/u
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
If you had a maf, you might need to lower the tps voltage until you get a custom chip so it will idle below 1500rpm. However, since you have a map then you will NEED to get a custom chip asap.
I've got my tps voltage at .35 until I get a chip...I guess it couldn't hurt to try but I don't think it will make much difference on your car.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 161,000 miles, !cat, 9" K&N
Car: An Ol Buick
Engine: Vsick
Originally posted by GTA91:
Thanks guys! Anyone else? Later
Read my post about IAC min idle min opening at the prom section.
Car: '91 GTA
Engine: 402ci LS2
OK... thanks!
'91 GTA:5.0TPI-5-spd, Hypertech Stage 2 chip, 160stat,!TB,!Cat, K&N, Flowmaster muffler, Accel Coil,TPI Air Foil, 1LE Alum DS, poly-tranny mount, KYB's all around, & a Hotchkis Strut tower brace.
Mods in progress:
-L98 w/ZZ4 cam/springs
-Edelbrock headers
-3" flow setup
Future:
-T56/heavier clutch
-Hurst or Ripper
-4.10's
-Ram Air II Hood
-1.5" Springs
-Rebuild suspension!
Others:
-39 Chevy coupe
350/350/3.55posi
-52 Chevy p/u
-77 Bonneville 400PONTIAC/400turbo/posi
Original 50k mile 2 door... Gramp's old car!
*** Gotta love those Poncho's***
Mods in progress:
-Edelbrock headers
-3" flow setup
Future:
-T56/heavier clutch
-Hurst or Ripper
-4.10's
-Ram Air II Hood
-1.5" Springs
Others:
-39 Chevy coupe
350/350/3.55posi
-52 Chevy p/u
