How much should FP drop at idle?
Old Jul 23, 2007 | 02:23 PM
Jeffrey Fontaine's Avatar
Car: 1992 Z/28
Axle/Gears: 2.73's I think
According to the article here:
http://leetwanker.homeip.net/TPITuning.pdf
Fuel pressure should drop 1 psi for every 2" of vacuum. Therefore, since my FP w/ engine off is 42psi, when at idle, it should go down to about 33psi (assuming 18" of vacuum)? My idling FP is around 38psi, so maybe my fuel pressure regulator is bad? After 30 mins (with key on, engine off), my FP drops from 42 to about 26psi.
I am in the process of putting the car back together but I'll kick myself in the face if I put it all back together again and then have to pull it apart AGAIN to swap the regulator. I still can't get a good answer what the best one out there is, you get 100 different answers.
Jeff
Old Jul 23, 2007 | 02:30 PM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
Re: How much should FP drop at idle?
my car does about the samething and it runs fine. but if you have the money do an afpr.
Old Jul 23, 2007 | 02:56 PM
Guest
Guest
Posts: n/a
Try checking the FP with the engine running and no vacuum applied rather than engine not running.
Old Jul 23, 2007 | 09:55 PM
1987ZTPI's Avatar
Car: 1987 IROC-Z
Engine: 310 lb9
Transmission: SEMI STOCK 700R4
Axle/Gears: 3.45 9 BOLT
dude your perfectly fine if you can hold 26psi for 30 mins i want ur fpr cuz mine was messed serious when i got the car it held 1 psi for 2 min now it holds 14-18psi for about 15 min and that is **** but it still runs great
777Shock777
Oct 29, 2015 04:30 PM
IROCtometal
Sep 20, 2015 11:08 PM
db057
Sep 4, 2015 07:57 AM
IROCtometal
Sep 2, 2015 02:01 PM
