2001 Mustang GT
Old Dec 27, 2000 | 07:13 AM
Kyle F's Avatar
2001 Mustang GT
I drove one today and was really impressed. Sorry but the car felt great to drive. Ther gears were tight and quick(5 speed). Handeling was tight and aggressive (17" wheel package). So I decided to romp it a little and was kinda dis apointed. The engine wanted to go hard, but I could feel the gearing wasn't enogh for the OHC engine. Then I power sifter a 2-3 and hit the gears smoothly but the cluthch was wayyyyy to weak for this. Slippage ran wild. I would say this car would be able to drop 3-5 tenths off its 1/4 mile with a High po clutch and a set of 3.73 gears. This car had no problem with Traction on thos big tires, but it was harder than hell to see out of. Im not sure what the factory specs are on these, but it felt like a loe 14 sec car right out of the box and maybe a 13.5 - 13.9 car with a better clutch and gear. Well lemme know what you guys think.
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank, bearings, rings, and magnafluxed rods. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,SVO 24# injectors,MSD 6A, Hypertech Power Coil, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, MSD Wires, removal of A/C hardware and a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace
http://geocities.com/SunsetStrip/Garage/9548/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/4 ton 350, one of those NASCAR F150's ..... **** on Monkie
SOON TO BE A SUPER CHARGED TURBO WITH NOS ON A 500000 CU. IN engine
Old Dec 27, 2000 | 10:58 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Now take a test drive in a new Camaro or Firebird with an LS1 and 6 spd. You will see why the LS1 spanks the Mustangs every time!
D&Z Performance
"Putting Power to the Pavement"
Old Dec 27, 2000 | 12:10 PM
Kyle F's Avatar
I know, I am just saying that the Mustang could be faster from the factory if they would have done some common things that wouldn't be to hard. Say equip them with a 3.4X rear and a stronger clutch. This would wake them up.
Old Dec 27, 2000 | 01:01 PM
Bill91Z
Guest
Posts: n/a
Please continue discussion on opinions of the new stangs on one of the many nontech boards such as nethirdgen. I fail to see where this has relation to Tuned Port injected F-bodies or the like.
Thanks for your understanding.
ndndndnd
Sep 28, 2015 08:00 AM
okfoz
Sep 22, 2015 03:37 PM
scottmoyer
Sep 7, 2015 07:06 PM
